🚀 Meet Flint 3e (GL-BE6500) — the BE6500 dual-band Wi-Fi 7 router built for next-generation speed, stability, and security
Wi-Fi 7 router built for next-generation speed, stability, and security.
Whether you're streaming, gaming, or managing your smart home, Flint 3e is the smart choice for the Wi-Fi 7 era. :high_voltage:
:sparkles: Key Features:
:antenna_bars: Wi-Fi 7 Speeds – Up to 688 Mbps (2.4GHz) + 5764 Mbps (5GHz)
:electric_plug: Five 2.5GbE Ports – Ideal for ultra-fast wired connections
:locked: VPN Speeds – Up to 680 Mbps with WireGuard® and OpenVPN-DCO
:laptop: Flexible Expansion – USB 3.0 for extra connectivity
:backhand_index_pointing_right: Subscribe now to learn more: https://link.gl-inet.com/post251031a
Would be interesting to post the differences between Flint 3 and Flint 3e
From what you posted, it's exactly the same as Flint 3
By the look of it, the Flint 3 is tri-band, whereas the Flint 3e is only dual-band, not having a radio in the 6GHz band.
Yep + other chipset for WiFi
OpenWRT version is???
This gonna be a funny one :backhand_index_pointing_up:
The 3e looks like a nice option for those who will trade 6Ghz for better 5Ghz throughput (which is probably a lot of people!).
512MB Nand for Flint 3e vs 8GB for Flint 3 and minus the increasing 6GHz band doesn’t seem futureproof for me.
“Futureproof” is such a stupid word and thought at the speed technology moves. Honestly, how long do you need a $100 device to be top spec? Seriously folks, get a grip.
I want a router with at least double 10gbps. Waiting with my flint 2 until then…
i hope next version becomes OpenWrt friendlier :+1:, + more competing with the Flint 2 using a mediatek chip.
For me all this Flint 3 feels like a downgrade, the 3E even at its worst, the only good side of it is when you place this router purely for wifi then it is better only if so aslong the hw accerelation works.
I understand it is just a case of demand and supply for these chips and why they get choosen, but please prioritise mediatek :slight_smile:
Yes and flint 2 thrown into the compare. I just recently bought the flint 2 over the flint 3 because of its substandard CPU / wireguard speeds.
Please some advice here. Planning to get a home Gl.iNet router. Currently using a Puli AX. Would a Flint 2 still be better than Flint 3. Thanks in advance for your advice.
I bought the Flint 3 to replace my Flint 2…
Returned the 3 as my older 2 was a much better performing machine.
This new Flint 3 E is an option but I will do a bit more research before retiring my Flint 2.
195,90 € + vat is not what I expected for a crippled Flint 3E compared to Flint 3.
Update1: Discount code arrived 90 mins later, 156,80 €+ VAT. Recently Bought a Beryl AX for 52,39 € incl. VAT to accompany my Flint AX1800.
Update2: Flint 3 ( the Non-E Triband) now is 163,35 € incl. VAT.
For real, I don't know what they've been smoking…
Wow what Price :flushed_face: i want to buy but the Price with difference to Flint 3 i not understand.
