🚀 Meet the Upcoming GL.iNet KVM Series
:rocket: Meet the Upcoming GL.iNet KVM Series
:laptop: Comet Pro (GL-RM10)
Introducing our Comet Pro Remote KVM over WiFi, giving you remote access to your computer, workstation, or server anywhere.
:link: Learn more: Comet Pro (GL-RM10) - GL.iNet
:electric_plug: Comet PoE (GL-RM1PE)
The upcoming Power-over-Ethernet version of the Comet (GL-RM1) is designed for simplified single-cable setups.
:link: Learn more: Introducing the Comet PoE - GL.iNet
#GLiNet #CometPro #RM10 #CometPoE #RM1PE #RemoteKVM #ServerControl #RemoteAccess #PoE #TechLaunch #StayConnected #NextGenTech
Will the comet pro work with the existing atx module?
Yes, Comet Pro works with the existing AXT board.
The ATX module is basicly a PCI-E card you can put in your pc as pc hardware, then attach leds (case cables) on it for powering on the pc or off.
The card comes with extra led connections to wire from case to card and card to motherboard, this way the mechanical button keeps working and you can use the comet.
Then you can basically use the comet to start or restart or shutdown the pc.
