Mesh for Gl-iNet Routers
Is there a way to set up Mesh for GL-iNet routers? I have GL-XE3000 as my main router. And a few ASUS Merlin routers. How can I incorporate all these routers with same SSID?
I have ethernet cable to connect each router.
thanks
Unfortunately, xe3000 does not support mesh.
You can put Asus router in AP mode and connect to XE3000’s LAN.
As you have a few routers, you may need a network switch.
Change the the SSID and key to the same in all the AP and enable 802.11kv.
