Mg1300 firmware 4.11.2 - wireless repeater
5g wireless repeater unable to connect to any wireless network
2g works ok
please check
*further issue - while 5g wifi network connection fails, the router's own 5g wifi would dissappear, requiring manually turning off and then on 5g wifi (if you still have connection to the router since 5g wifi offline)
I just upgraded to 4.11.2, keep settings, and successfully connected the repeater to a 5G AP. Also to a 2.4G AP. I'm connected to the router over 5G as well. It took a minute after the Mango2 had connected to the 5G AP for the internet connection to be active.
Not an exhaustive test, of course.
thanks for checking for me, i changed to ac only, 20mhz width and 40 something channel then tried to connect to the cafe wifi, it couldnt establish connection and then loses its own wifi
I unplugged power, bring it home and triwd to connect another 2 5g wifis at home and same thing happened, still havent found what setting i screwed up
2g connected quickly
so i decided to reset firmware and redo settings in the following sequence
  1. wifi country=de, repeater can connect to 5g channel 149
  2. change wifi country to us
  3. set 5g wifi to 20mhz width, channel 36 (manual channel) and ac only
  4. repeater can still connect to 5g wifi
i guess its case closed thanks
Thanks for the update and for sharing the solution.
Just wanted to remind you to check the country/region code in Luci.
If you still encounter any issues later on, feel free to export the logs and send us a private message so we can analyze them.
How to export logs:
How to send private messages:
Likely related: [GL-MG1300 / Mango V2] 5 GHz repeater fails and wedges sta1 ("Network is down") when switching upstream AP channels while connected to 5 GHz AP
hi,
i did change the router's channel band while connected to the cafe wifi
the router would then have problem connecting to 5g wifi since then until i resert firmware
Ya, it’s likely for the same reason in my post. You’re trying to change the band while also being connected to the same band and the mango doesn’t cope with that properly. It only fixes itself if you restart it (no need to reset the firmware) and allow it to connect to the upstream AP on the proper channel and then it starts repeating all before you actually connect to the mango itself.
Hopefully someone from glinet will be along soon to review these posts.
The 5Ghz radio downstream has to be on the same channel as the upstream connection.
Thank you for your feedback. We’ll try to reproduce the issue locally & update you in your thread if we make any progress.
So far, our initial tests don’t seem to have reproduced the issue.
dear colleagues, i am out at a cafe, tried to simply connect to a cafe 5g wifi, it crashes at scAnning for existing/saved wifi and router 5g wifi restarts itself.
edit: attached log to will.qiu
Thanks for sending the logs.
We found no evidence of a crash or reboot during the scans. The logs show a Wi-Fi client disconnecting and reconnecting afterward, but no attempt to connect to the café’s Wi-Fi in the current boot’s system log.
Could you help us check the following?
  1. How are you currently powering the Mango 2? Does the power source meet its 5 V / 2 A requirement?
  2. Do you have another device that can connect by Ethernet? If so, connect it to the Mango 2’s LAN port and start a 5 GHz Repeater scan from that device. Keep your existing device connected to the Mango 2’s 5 GHz Wi-Fi during the test. Does the wireless device still disconnect?
  3. If Ethernet is unavailable, connect your current device to the Mango 2’s 2.4 GHz Wi-Fi instead, then try scanning for and connecting to the café’s 5 GHz Wi-Fi again. Does the issue still occur?
hi will
  1. i run the mango on powerbank (usb c to usb c)
  2. i'm back home now, tried to get mango 2 to connect my home 5g wifi, i didnt get disconnected from the mango2 but now it cant connect to my home 5g wifi
edit: extra info, in my first attempt to connect cafe wifi, mango 2 showed that the wifi channel is a dfs one
I had a similar issue; after updating the firmware to 4.11.2, Mango-2 couldn't connect to my home 5G WiFi. The only solution was to change the home router channel from 149 to 60.
@will I’m available to send whatever logs you need and run whatever testing you need. Feel free to send me a PM or respond in my thread (there are some logs there already).
i have tested with various pd power bank and pd wall charger, there is no concrete proof the issue is related to power supply
This is just flat out speculation: But since the Mango 2 is not "legal" in the US, I wonder if there is some sensitivity to channels. Like @Rotor said. Mine is DE while I am in PT. But DFS would definitely affect me.
