Micro SD card not working on 4.8.2 (Slate AX)
On my GL-AXT1800, micro SD card is no longer being recognized after updating to 4.8.2. I’ve tried seemingly everything: updating with the SD card installed vs not installed, while keeping / not keeping settings, resetting / rebooting multiple times. The card never once showed up in the “Network storage” section. Reverting to 4.6.11 solves the problem immediately.
My card is a 512 Gb Lexar Silver Plus.
Could you please provide the system logs to us via private message from versions 4.8.2 and 4.6.11 after inserting the SD card so we can conduct further analysis?
How to export the system logs:
How to send private message:
I do not have an option to send you a private message. This is what I see:
I upgraded your level, now you should be able to send a PM.
Thank you, PM sent.
Thank you for your log.
We have asked our R&D team to look into this issue.
It currently appears that updating the kernel version has caused compatibility issues with certain SD cards. Resolving this issue may take a considerable amount of time.
In the meantime, please continue to use version 4.6.11.
