Hi, I just got a Microuter N300, upgraded to v3.211 and have connected its Ethernet port directly to an Arris SB8200 modem’s Ethernet port with a cat-6 cable. I would like to use the Microuter as a standard wireless router, sharing the cable modem connection over the 802.11 interface. The modem is running and on the internet according to its indicator lights but the Microuter always states that “No cable detected in WAN. Please plug in an Internet cable.” I’ve tried multiple things such as resetting the modem, resetting the router, etc.
I’ve checked and the device is currently in the default “Router” mode. It actually doesn’t let me switch to access point mode because it thinks the Ethernet port is disconnected.
The same story goes for me. Upgraded to the last firmware. Got No cable detected in WAN. Please plug in an Internet cable.
Firmware ends with 3.203 didn’t have such error. Cable is working. Tested with a few devices.
Rolled back successfully from 3.211 to 3.203, waiting for the FIX.
Thanks for the suggestion. I rolled back to 3.203 and have the same problem as before. Also I tried 3.102 and the same problem exists as well.
Interestingly, during the router’s startup sequence the modem’s LAN indicator light shows some activity but after the router boots up the light goes dark indefinitely. I may need to look into what kind of options the microuter’s ethernet controller’s driver has to see if tuning any of them will get it working, or maybe it’s a cabling issue and for that I’ll have to wait until I get some new cables delivered to debug.
I’ve performed the requested steps and attached the kernel log using ssh and dmesg: microuter.dmesg.zip (7.9 KB) Update: Added system log: microuter.logread.zip (7.4 KB)
I am unsure exactly how to capture the system log. Does that require installing the LUCI administrative console?
I noticed there were lots of changes to the mtk_eth_soc driver from Linux 4.14 to 5.4 (and even more to 5.16) so I attempted to install plain openwrt 21.02.1 from OpenWrt Firmware Selector . Once I installed it and configured the ethernet port for WAN usage, it was able to properly detect the cable modem as a working ethernet connection and get a public IPv4 address over DHCP so this seems to indicate that the old version of the ethernet driver just had some bugs or missing capabilities. The internet is not working yet but that might just be an incomplete OpenWrt configuration issue on my part or a problem on the ISP side. I’ll see if I can get it to work correctly.
I’ve the same error, and after reset the modem and changed the ethernet cable, I realized that the 3.211 fw was the issue. I have to rolled back to 3.203 and now is working.
I also have applied the 3.211 fw to the AR150 and it stops detecting the eth cable also, so It looks like the AR150 is having the same 3.211 issue.
I’ve to rollback to 3.203 this weekend, since the remote mgmt is broken.
@alzhao Why is the firmware for the N300 much more buggy then for other GL iNet routers? Of all my GL iNet products, the N300 has had the most firmware issues, and has cost me more time then all my other GL iNet routers put together.
