I bought a Mifi board and 3G/4G a couple of months ago before the cases were available. Would it be possible to buy a case on its own?
@simon, unfortunately, it is not compatible. The old boards will not fit in the new case. The case is available now. You can check this in our website. You can buy the new finished product and reuse the 3G/4G module you are using.
Ah, OK, that’s as good, I’ll order a case without a module. Thanks!
