Recently I’ve bought Mifi with two ethernet port. Can I know how to change the both ethernet port to the LAN port? Thanks
you can ssh to the router, then modify /etc/config/network
ensure the following lines’ contents are correct
config interface lan option ifname 'eth0 eth1' ... config interface wanoption ifname 'eth0'#remove this line
Hi! I managed to change the setting and working. Thanks
Hi there,
I bought a GL-MT300A ext and I’m new to all this… I need boot ethernet ports to work as LAN, too
Can anyone please provide a step by step guide how to “ssh” to the router on Windows 10 (I have PuTTY) and change the specific setting mentioned above.
Edit: now I know how to use vi… but don’t find the mentioned setting above. I only have:
config interface ‘lan’
option force_link ‘1’
option macaddr ‘e4:95:6e:40:7e:fc’
option type ‘bridge’
option proto ‘static’
option netmask ‘255.255.255.0’
option ip6assign ‘60’
option hostname ‘GL-MT300A-efc’
option ipaddr ‘192.168.8.1’
option _orig_ifname ‘eth0.1 wlan0-1’
option _orig_bridge ‘true’
option ifname ‘eth0 eth0.1’
config interface ‘wan’
option macaddr ‘e4:95:6e:40:7e:fd’
option proto ‘dhcp’
option _orig_ifname ‘eth0.2’
option _orig_bridge ‘false’
config interface ‘wan6’
option ifname ‘eth0.2’
option proto ‘dhcpv6’
config switch
option name ‘switch0’
option reset ‘1’
option enable_vlan ‘1’
@alzhao @others
Which lines should I change or remove?
Thx a lot
Here is the guide to use ssh and edit files in the router.
Use winscp if you are not good at vi
