Hello
I would like to know if it’s possible to change the IMEI of the gsm modem in the MiFi. The MiFi I own has an EC20-E modem.
Kind regards
Hello
Kind regards
Of course it’s possible but Mr. Plod take a dim view!
Off course it’s for testing purposes. It prevents me from buying 10+ devices (which isn’t possible budget wise for my home project)
I found an AT-command (EGMR) but it seems to take only the correct (factory) IMEI as an argument.
After some more experimenting it seems to work, but only from time to time. Best chance is when the device just booted. Give the modem some time to handle the command before looking to the output. It might be better using a direct tool to send the AT commands and not by putty
Spirou_, could you mind to explain for me how to do it? Do you send AT commands from the router (using a script?). Did you achieve more or less stable work?
Yes it’s working stable. Just use the GUI to send AT commands and search for EGMR
I read that there was a package that could modify it.
IMEI (repair)
AT +EGMR=1,7,"123456789101213"
A true hero emerges!
Anyone know if this will work with MUDI?
Yes, I checked the work on Mudi. But to display the result, you need to reset the modem on the main page, although when you request imei via the terminal, the result is visible immediately. Tested on Mudi EP06-E
Hi I can’t do it in this router GL-AP1300, thanks in advanced
Hi can u help me please. I want change imei for EC20-CN. Can u write me
@nero12 Hello . Can you please tell me what commands did you use to change imei to MUDI ? Thanks
Blockquote
AT +EGMR=1,7,"352811047679117"
Blockquote
@nero12 thanks for your answer. It will not make it difficult for you to write in a little more detail how to do this. Where to enter this command, etc. Thank you
In the UI , modem status section, find AT command tools
Then choose manual command and input the AT commands.
@alzhao thank you very much for your help! I will try and post an answer.
Is there a “Full reset” command that includes putting the modem IMEI back to factory as well as the host Mudi?
Merty Christmas all
I don’t know a method to fully reset the modem to factory status.
The factory IMEI is printed on the module so you can change to that manually.
