Hi, I just noticed that if the external USB port is not drawing enough power from the port it powers down after a few seconds.
I had to use a USB hub and connect some dummy load to use the flash drive without the port powering off. Is there a fault with the unit or is that by design? Is there anyway around it?
I am running LEDE trunk on a mifi, can you tell me what the raw gpio is so i can turn the USB port on while the mifi is plugged in?
Also, why would you stop power going to the USB port while the mifi is plugged in? Is there no way to tell when the battery is full to reconnect the USB power?
