Hi I am trying to revive my MiFi. I last looked at it over a year ago and can’t remember what I did but I think I tried to install an OpenWRT upgrade which included a firmware image.
But I can’t get anything in/out of LAN or WAN ports. I have tried different cables, and different host ethernet ports (Linux on one desktop PC, Windows 10 on a laptoip). I’ve followed the instructions about setting host IP to 192.168.1.2 etc. Trying the Windows troubleshooter in desperation tells me it thinks there is no ethernet cable connected but as mentioned I’ve tried 2 cables, both of which work without problems in other situations.
I originally bought the MiFi second hand and it wouldn’t boot or do anything, which is why I immediately flashed the firmware (a long time ago as I say so can’t remember exactly how).
Could it just be that the LAN/WAN ports are physically dead? Any way to test?
I have a USB UART device (I am not very experienced with it). If I connect it to the pins on the MiFi I can get into the uboot console by following the hold reset button, wait for 6 flashes etc procedure. I can send commands and read output from uboot.
Everything in uboot indicates that the installed firmware is AR150
The boot messages, filenames etc all indicate that I have installed AR150 firmware. Could this be why the LAN/WAN ports don’t work? Could it mean that the uboot server is on a different address ie not 192.168.1.1?
Without ethernet access I can’t use TFTP to flash firmware. Is there a way without TFTP?
The current state is:
It turns on and goes through what seems like a normal boot process with flashing LEDs etc
With USB/UART I can access the uboot console with picocom in Linux. Everything looks ok (I think) except talking about AR150 instead of MiFi
I can type commands to uboot and it seems to respond as I expect
If I try to use TFTP to transfer a binary to flash, it hangs for a while then tells me it cant find the host (EDIT: error message is ## Error: ping failed, host 192.168.1.2 is not alive!)
I can’t ping the router from the host
According to the flashing lights on the front it seems I can (my original typo said “can’t”) put it into uboot HTTP mode, but I can’t access 192.168.1.1 in any browsers/OS I’ve tried
Any ideas? This seems to be a nice device I hate having it sat unused in a cupboard. Being able to get into uboot makes me think it’s not dead… unless the LAN/WAN ports are physically broken.
EDIT: I thought I’d found a way to transfer the file over serial/UART using kermit… but it depends on telling uboot to wait with the loadb command. But it seems the uboot I have on the mifi doesn’t include that command.
This is the full terminal output (on Linux/picocom trying to initiate TFTP transfer with run lf):
uboot> run lf
## Error: MDIO_BUSY!
## Error: unknown eth speed!
Ethernet mode (duplex/speed): 1/10 Mbps
Using eth0 device
Linux (and Windows when I tried it) always tells me that the ethernet cable is unplugged, at all times whether it’s plugged in to WAN or LAN on the router.
Here is some other uboot output in case it’s useful (it’s a lot, hope that’s ok). I get a lot of Error: MDIO BUSY during communication but it seems unrelated, maybe due to imperfect connection config with picocom? Anyway I’ve omitted long repeats of it
Uboot boot process:
* U-Boot 1.1.4 (Jul 9 2015) *
AP121 (AR9331) U-Boot for GL-AR150
DRAM: 64 MB DDR2 16-bit
FLASH: Winbond W25Q128 (16 MB)
CLOCKS: 400/400/200/33 MHz (CPU/RAM/AHB/SPI)
** Warning: bad env CRC, using default,
use 'saveenv' to save it in FLASH
LED on during eth initialization...
ag7240_mii_setup: MDC check failed
Hit any key to stop autobooting: 0
Device calibrated. Booting ...
Booting image at: 0x9F050000
Image name: MIPS OpenWrt Linux-3.18.23
Created: 2015-12-30 10:01:18 UTC
Image type: MIPS Linux Kernel Image (lzma compressed)
Data size: 1198200 Bytes = 1.1 MB
Load address: 0x80060000
Entry point: 0x80060000
Uncompressing kernel image... ## Error: LZMA error num: 1
## Error: failed to execute 'bootcmd'!
HTTP server is starting for firmware update...
HTTP server is starting at IP: 192.168.1.1
HTTP server is ready!
I am not an uboot specialist but can you try to set the eth speed of your PC (where you run the TFTP server) to 10 mbps only? I would guess that auto-negotiation does not work.
Thanks for the idea. I tried it and tried the tftp update again but the output was almost the same — only difference was the Ethernet mode (duplex/speed): 1/10 Mbps line was missing this time… maybe that line (before I’d changed the speed) was the result of negotiating the speed? I’m guessing, out of my depth with networking stuff.
I have something that physically fits but don’t think it’s compatible (it’s USB to RS485, used to communicate with a solar controller). I’m sure I could buy a USB to ethernet, want to make sure I’ve exhausted all other options before spending any money. Times are tough enough that I’d probably feel obliged to buy from Aliexpress too so would be a multi-week wait. I’ll do it if I have to.
Thanks for confirming about the AR-150, and that ethernet ports are the only way to update this router. I was hoping that uboot would allow serial transfer but I think I’ve learned that there are different versions and uboot on this router doesn’t allow it.
I’m unconvinced that another computer will fix this as I’ve tried various combinations of OS, cable and physical computers and none of them have seen anything from the ethernet ports. So I can only imagine that there’s a hardware fault with the ports and that sadly for me this is a write-off.
