I got the [GL-MiFi 4G Smart Router]EP06-E 4G EU/EMEA/AU/BR and I should be able to send/receive text messages with this router.
Only when I look at the tutorials there should be a “message” category below the Application section.
I don’t see this.
Must I maybe first install a Plug-in? when I search on SMS I get a lot of results. So can someone maybe tell me how I can get this work.
I got a 4G sim card with unlimited data, but after I have used 5Gb I need to request a new Gb per sms. Now I remove the sim from the router, put it into a phone and then top it up and then put the sim back in the router.
Installed the newer firmware (you send me) but still no Message option shown below Applications?
I got: Plug-ins / File sharing / Remote access and Portal.
And when my bundle limit is reached, I need to send a message to a number then I get more Gb available.
Also when my bundle is “empty” then I can’t access the router settings anymore. Even from my telephone with 4G connection it isn’t accessible? So now I need to remove the sim card, put it in a phone, top it up and then put it back in the router. But this isn’t workable for me, because if that happens during a test and I can’t request quick (within 30 sec) new Gb. then I need to start the test all over again
No problem thank you for the print screen. I got the message menu there.
A big problem is when my databundel is “empty” I can’t access the router anymore. So then I am not able to send a message to the provider to top it up. So still I need to change the sim card to my phone (to top it up) and then put it back in the router.
When I then send a message to my telecom provider (via the router) I never get a message back.
I need to send it to 1280 with a special text.
When I use another text (on my phone) or ask for another 1GB I always get a message back. But in this case (via the router) I never get a message back so it looks like it doesn’t work correctly.
I only get a message from my provider when I used 50% and 100% of my bundle.
and maybe that is because the fact that I can’t top-up my data bundle. so it is empty at that time and then I need t send a message to the provider to get another 1GB etc. etc.
