Hello All,
I have been a happy owner of a GL-AR750S-Ext Gigabit Travel AC Router (Slate) except for LAN-to-WAN throughput issues. I have gigabit internet connectivity and if I put a device on the LAN side of the AR750s, I am limited to around 300-450 megabits/sec, however, if I place the same device on the WAN side of the AR750s I can attain 980+ megabits/sec.
The reason for this posting, is that I would like to seamlessly migrate all of the settings from the AR750s to the MV1000W. I don’t currently use the WiFi aspects of the AR750s, so that, I only need to move the LAN IP & DHCP Reservation List, OpenVPN Server Configuration and certificate & keys, port forwarding rules & ports, DynDNS configuration, etc.
Does anyone have a suggested method to essentially and successfully backup the AR750s settings and restore them as appropriate/desired to the MV1000W?
Can I literally perform a “backup” on one router and “restore” it into the other one?
Thanks, in advance, for any help!
