Mimo 4x4 with GL-X3000
Hi have made a search before posting here
I have a Maxwell mimo 4 5g external antenna. My question is that the four cables from the antenna are marked 5g on each connector and on the router the external sockets are marked Main\Div\mimo 1\mimo 2..
So that makes me think there must be a sequence for these antenna cables to be connected.
Any help would be much appreciated as this antenna is used on a Narrowboat in secluded areas.
Thanks in advance
Ok all have sorted out the issue regarding antenna connection for mimo 4.
Had two sets of paired cable all marked 5g. Have connected 1 pair to main and div. And the other pair to mimo 1 and mimo 2.
Everything seems to be working perfectly.
