I have a GL-AR300M and I absolutely love it. It works better than much bigger and expensive routers.
I would like to improve the WLAN performance by installing a Mini PCI-E card, which will be used to connect the router to another network as client and then using the internal one just for the AP network.
I opened the router’s case, but I noticed that the board doesn’t have a Mini PCI-E slot. I see on the website that there are 10 PCI pins; is there some sort of adapter I can use to connect a normal notebook WLAN card?
I would like to purchase the module only. I have the router. I take full responsibility for installing module and required software myself. How do I purchase the 5G module only shipped to UK?
