Just received my gl-mt300n. How do I install the minidlna server? I tried via the install packages in the basic and advanced sections. It installs with errors on some codecs, but I don’t see any tabs for configuring it?
Any help appreciated.
Thanks
Thanks
You need to install “luci-app-minidlna” if you want the UI. It should appear in “service” section.
For some reason, when installing packages, the UI always shows error. You can use ssh.
Yes, ssh install seems to work fine.
Thanks!
Can someone post a how to for this. Just bought another gl router just for this.
