Hi, i am new to this topic and need some advise.
Here’s what I’d like to accomplish:
I have 3 sites.
Site A has a Windows PC and a network printer.
At site B and C there is only a network printer.
The Windows PC must be able to print to all 3 network printers. The network should also connect automatically. (e.g. after a power failure or restart of the PC).
I now had the idea to use 3 GL.Inet routers and to link them via GoodCloud. Will this work as desired and are there minimum requirements for the routers? For example, would 3 Mango (GL-MT300N-V2) be enough or do i need a better model as main-node?
