Hi all,
I'm using a GL-MT3000 with a custom OpenWrt firmware built using the official OpenWrt Image Builder (not GL.iNet's own firmware). Everything runs and detects correctly except no Wi-Fi radios show up at all, no phy0, wlan0, etc.
There are no Mediatek ax firmware blobs in /lib/firmware/ or /lib/firmware/mediatek/ (only unrelated older firmware for mt76x2 and similar).
What I've tried
Installed all relevant kmods (kmod-mt76, kmod-mt76-connac, kmod-mt7981-firmware, etc.) from the opkg feeds for mediatek/filogic/24.10.
Searched the feeds and manually with opkg for any firmware for mt7981, mt7976, mediatek, ax, wifi6, etc.
There are no suitable firmware blobs (.bin files) installed or available via opkg for mt7981/mt7976/mediatek Wi-Fi radios.
Because there is no firmware, the radios never come up, and /sys/class/ieee80211/ is always empty.
What works (and doesn't)
kmod packages and kernel are all installed and match (no mismatch or install error).
Only the "WO" (Wi-Fi offload) and kmod-* packages for mt7981/mt7986 appear. These do not contain or install any actual Wi-Fi firmware blobs.
On factory GL.iNet firmware, Wi-Fi radios work fine; on official/snapshot OpenWrt, radios work only if the correct firmware blobs are present.
Official sysupgrade or imagebuilder builds from openwrt.org do not include the Wi-Fi 6 firmware blobs by default.
What is missing?
The problem:
OpenWrt's public repository and image builder for the GL-MT3000 do not provide the proprietary Mediatek/AX wireless firmware blobs (mt7981/mt7976 .bin files) needed for radio operation.
Without these, even with all kernel modules loaded, the device has no Wi-Fi support.
Questions for the forum:
Is there an official package or OpenWrt-sanctioned source for the required Mediatek Wi-Fi firmware?
Where do users currently obtain and copy the needed firmware blobs when building for filogic/GL-MT3000?
Is there a reason this firmware isn't available in the mainline feeds/installer, and is that likely to change?
Is there a documented, up-to-date list of exactly which files/directories are needed, and their canonical source?
Any help or pointers appreciated--this roadblock currently prevents any official OpenWrt imagebuilder/DIY install from supporting Wi-Fi out of the b
