I am not sure this belongs here as I don't see a mobile app category.
Similar to the Google Home app I use with my Google Nest router, I would like to have similar notifications in the GL-iNet app:
- New Device
- Password Mismatches
- Lost Connection
This would be very usefull, especially New Device.
@acong Thank you. It seems odd that you have to connect your router to the cloud (potentially making it less secure) to add a security feature.
admon
4
You can disable all remote access features, in that case, the router is as secure as before.
Using a cloud service is needed due to sending notifications requires the Android (or iOS) Notification system.
system
Closed
5
