Mobile Roaming active by default?, GL-XE3000
Hi Community,
I have a new GL-XE3000 and want to know if international roaming is activated for mobile connectivity by default?
And how can I check the status?
Best regards,
Klaus
You can check (and enable it) using the manual SIM settings, see:
Thank you @admon
