My internet is rock solid. Is this needed for cable or fiber type modems? Or is that really put there for less stable connections? I.E. cellular or hotel wifi, etc?
FYI, I squelched the spamming by setting cron log level 9 (warn in luci).
What does it actually do if the internet drops?
Just curious.
I have also seen this. I could be wrong, but I suspect this is checking for cellular modem. Since I don’t have a cellular modem, and I want more info in the system log, just not these repetitive errors, I used the ssh CLI and commented out the 3 lines in /etc/gl_crontabs/crontabs.d/modem_status_monitor
#* * * * * . /lib/functions/modem.sh;check_ip
#* * * * * sleep 30;. /lib/functions/modem.sh;check_ip
#*/2 * * * * . /lib/functions/modem.sh;modem_net_monitor
Before doing this, since my gl.inet device is behind a primary router, and I don’t use Multi-WAN, I tried disabling the internet status checking. This stopped the redundant pinging of 1.1.1.1, but did nothing to stop the above log errors.
Yes, there is a bug EVEN IF multiwan is disabled, the cron job does NOT close!
Workaround:
ps -STOP <pid#>
Once it is suspended it will have T status:
18214 root 1232 T /bin/ash -c sleep 30;. /lib/functions/modem.sh;check_ip
I’ve suspended it for over a month and the modem is working fine!
Thanks for replying! Yeah, I tried that for a hour late last night off peak usage time and saw no issues with it.
But then I restored it and decided to post this question here to see why it is activated in case I missed something.
How long have you had this commented out?
Thanks for replying! So it is a function just for multiwan?
Workaround:
ps -STOP <pid#>
Will that survive a reboot? I’m still fiddling with this new router and rebooting alot for testing things.
I guess so and also it does monitor the hen the ip changes so that it can request a DHCP renew packet to the isp.
No. You can though script it easily just one linear.
