Modify the keyboard and mouse device properties of comet
We plan to add the ability to configure the keyboard and mouse device name in the UI in version 1.4, but before that, we provide a manual modification method.
You can try it when you encounter keyboard and mouse compatibility issues or need to modify the device name.
First enter the comet terminal.
By executing commands to simulate keyboards and mice of different manufacturers, the following are some common manufacturers' keyboard and mouse parameters. If you have a need, you can choose any one to try
Corsair
cat > ./etc/kvmd/override.d/hidname.yaml  << EOF
otg:
  manufacturer: Corsair
  product: 'Corsair Gaming RGB '
  product_id: 26995
  serial: ''
  vendor_id: 26944
EOF
sync
Logitech Inc
otg:
  manufacturer: 'Logitech Inc'
  product: 'Logitech, Inc. Keyboard K120'
  product_id: 49948
  serial: ''
  vendor_id: 1133
EOF
sync
Microsoft Corporation
otg:
  manufacturer: 'Microsoft Corporation'
  product: 'Microsoft Corporation<br>Wireless MultiMedia Keyboard'
  product_id: 95
  serial: ''
  vendor_id: 1118
EOF
sync
Dell Inc
otg:
  manufacturer: 'Dell Inc'
  product: 'Dell Computer Corp.<br>Multimedia Pro Keyboard'
  product_id: 8209
  serial: ''
  vendor_id: 16700
EOF
sync
After executing the command, reboot comet to take effect
When you no longer need it, just delete the configuration file and restart the device
rm /etc/kvmd/override.d/hidname.yaml
reboot
During the modification process, if the configuration file format is incorrect, comet may be inaccessible. At this time, you can try to restore the device by pressing the key for more than 8S.
So my mouse and keyboard icons in the control program just stay red and give a message about mouse free inactive. So I tried this, but now the system just gives a white page when I connect to it. However my device has no keys on it, so what do you mean by pressing the key for more than 8S, and when would I do this? I guess you mean the button it has? I did this and nothing has changed. How do I get access to the kvm again?
Long press 8S to restore to factory settings
Was this resolved on the latest firmware?
Since 1.4 version, we can configure the device identity in web UI > Settings > System > Device identity. Please see attached.
