Mounting point dimensions of Mudi PCB
I am building a 3D printed enclosure for Mudi. Does anyone have the precise mounting point measurements of the Mudi V2 PCB?
Ignore the fancy red arrows, they are for another purpose.
Sorry. We are unable to provide shell model design drawings to the outside world, since the design documents are highly confidential.
Hi Bruce, and thank you for your reply.
I don’t need the enclosure design, because that design is precisely what I need to improve and adapt for my use case. It would save my time and cost of full 3D scanning if I had the measurements of the four outermost PCB mounting pads (the four corner pads, for lack of a better description). I need only the measurements of the four outermost pads because my custom enclosure will use only those four pads, not all seven that I counted on the Mudi PCB.
Surely you could help with simple center-to-center measurements of those four pads? If you happen to have the Gerber file for the PCB (without layer data, copper traces, etc. is fine), that would be even more helpful - and save my time & scanning cost - for the revised case design.
Thanks much.
In fact, I am not building an enclosure, per se, merely attaching the PCB to a lattice-like structure that will be installed in a custom industrial application.
Truly sorry. We are unable to provide this document.
I ended up doing 3D scan + measuring mounting pads manually with caliper. If anyone needs schematic in future, send private message.
