I upgraded from 1.5.0 today. And Keyboard and Mouse worked RIGHT before upgrade.
I swapped Cable, rebooted, swapped usb name to Logitech and so on. NOTHING standby on the bottom corner.
Any ideas?
Any ideas?
Is your computer in sleep? If you update the firmware while your computer is sleeping, it won't be able to wake up your computer after the update. You'll need to find a way to manually wake up your computer.
No it is working and online. I can access it over parsec still.
Change your device identification to another one
I now tried Logitech, Microsoft and Default none work. Default worked before just fine
Try customize and modify the VID and PID. Just use a random number for it.
If it still doesn't work, you should check if there are any unrecognized devices on the controlled computer, update their drivers, and see if that resolves the issue.
That did not resolve it either…. Maybe reset the thing?
Today I tried a reset as I do not get a response after almost 2 weeks……
Still nothing……..
Holidays this week for Chinese New Year, official staff responses will be slow until at least next week now.
Legit after checking forum i wanted to export logs. It did not connect. Came to check it. Saw it blinking even tho its connected. Nothing except cutting power. Anyways. No clue what about this restart was different than the others but now it works like before. Changed legit nothin… Thanks anyways i guess??
