Thanks.
I took another snapshot of the logs and I see the routing line once, but the MAC address stated is a client on the MT1300⌠And I dont see the routing message all the timeâŚ
Sun Oct 22 15:27:25 2023 daemon.notice netifd: wan (24489): udhcpc: sending renew to server 100.64.0.1
Sun Oct 22 15:27:25 2023 daemon.notice netifd: wan (24489): udhcpc: lease of 100.105.221.10 obtained from 100.64.0.1, lease time 300
Sun Oct 22 15:28:27 2023 daemon.notice netifd: Network device âwanâ link is down
Sun Oct 22 15:28:27 2023 daemon.notice netifd: Interface âwanâ has link connectivity loss
Sun Oct 22 15:28:27 2023 kern.info kernel: [65419.119043] mt7530 mdio-bus:1f wan: Link is Down
Sun Oct 22 15:28:28 2023 daemon.notice netifd: wan (24489): udhcpc: received SIGTERM
Sun Oct 22 15:28:28 2023 daemon.notice netifd: wan (24489): udhcpc: unicasting a release of 100.105.221.10 to 100.64.0.1
Sun Oct 22 15:28:28 2023 daemon.notice netifd: wan (24489): udhcpc: sending release
Sun Oct 22 15:28:28 2023 daemon.notice netifd: wan (24489): udhcpc: entering released state
Sun Oct 22 15:28:28 2023 daemon.notice netifd: wan (24489): Command failed: ubus call network.interface notify_proto { âactionâ: 0, âlink-upâ: false, âkeepâ: false, âinterfaceâ: âwanâ } (Permission denied)
Sun Oct 22 15:28:28 2023 daemon.notice netifd: Interface âwanâ is now down
Sun Oct 22 15:28:28 2023 daemon.info avahi-daemon[5263]: Withdrawing address record for 100.105.221.10 on wan.
Sun Oct 22 15:28:28 2023 daemon.info avahi-daemon[5263]: Leaving mDNS multicast group on interface wan.IPv4 with address 100.105.221.10.
Sun Oct 22 15:28:28 2023 daemon.info avahi-daemon[5263]: Interface wan.IPv4 no longer relevant for mDNS.
Sun Oct 22 15:28:28 2023 daemon.warn dnsmasq[1]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sun Oct 22 15:28:28 2023 daemon.notice netifd: Interface âwanâ is disabled
Sun Oct 22 15:28:28 2023 kern.info kernel: [65419.299824] mt7530 mdio-bus:1f wan: configuring for phy/gmii link mode
Sun Oct 22 15:28:28 2023 kern.info kernel: [65419.307507] 8021q: adding VLAN 0 to HW filter on device wan
Sun Oct 22 15:28:28 2023 daemon.notice netifd: Interface âwanâ is enabled
Sun Oct 22 15:28:29 2023 user.notice mwan3[11675]: Execute ifdown event on interface wan (unknown)
Sun Oct 22 15:28:29 2023 user.info mwan3track[24981]: Detect ifdown event on interface wan (wan)
Sun Oct 22 15:28:29 2023 user.notice mwan3track[24981]: Interface wan (wan) is offline
Sun Oct 22 15:28:31 2023 daemon.notice netifd: Network device âwanâ link is up
Sun Oct 22 15:28:31 2023 daemon.notice netifd: Interface âwanâ has link connectivity
Sun Oct 22 15:28:31 2023 daemon.notice netifd: Interface âwanâ is setting up now
Sun Oct 22 15:28:31 2023 kern.info kernel: [65422.320161] mt7530 mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control off
Sun Oct 22 15:28:31 2023 daemon.notice netifd: wan (12279): udhcpc: started, v1.35.0
Sun Oct 22 15:28:31 2023 daemon.notice netifd: wan (12279): udhcpc: broadcasting discover
Sun Oct 22 15:28:31 2023 daemon.notice netifd: wan (12279): udhcpc: broadcasting select for 100.105.221.10, server 100.64.0.1
Sun Oct 22 15:28:31 2023 user.notice firewall: Reloading firewall due to ifdown of wan ()
Sun Oct 22 15:28:31 2023 daemon.notice netifd: wan (12279): udhcpc: lease of 100.105.221.10 obtained from 100.64.0.1, lease time 300
Sun Oct 22 15:28:31 2023 daemon.info avahi-daemon[5263]: Joining mDNS multicast group on interface wan.IPv4 with address 100.105.221.10.
Sun Oct 22 15:28:31 2023 daemon.info avahi-daemon[5263]: New relevant interface wan.IPv4 for mDNS.
Sun Oct 22 15:28:31 2023 daemon.info avahi-daemon[5263]: Registering new address record for 100.105.221.10 on wan.IPv4.
Sun Oct 22 15:28:31 2023 daemon.notice netifd: Interface âwanâ is now up
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: using nameserver 8.8.8.8#53
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sun Oct 22 15:28:31 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sun Oct 22 15:28:33 2023 user.info mwan3track[24981]: Lost 1 ping(s) on interface wan (wan)
Sun Oct 22 15:28:33 2023 user.notice route_policy: default_policy=0 mac_list=7C:50:79:00:C9:B3
Sun Oct 22 15:28:35 2023 user.notice mwan3[12602]: Execute ifup event on interface wan (wan)
Sun Oct 22 15:28:36 2023 user.notice mwan3[12602]: Starting tracker on interface wan (wan)
Sun Oct 22 15:28:36 2023 user.notice mwan3track[24981]: Stopping mwan3track for interface âwanâ
Sun Oct 22 15:28:39 2023 user.info mwan3rtmon[4693]: Detect rtchange event.
Sun Oct 22 15:28:40 2023 user.notice firewall: Reloading firewall due to ifup of wan (wan)
Sun Oct 22 15:28:43 2023 user.notice route_policy: default_policy=0 mac_list=7C:50:79:00:C9:B3
Sun Oct 22 15:29:44 2023 daemon.notice netifd: Network device âwanâ link is down
Sun Oct 22 15:29:44 2023 daemon.notice netifd: Interface âwanâ has link connectivity loss
Sun Oct 22 15:29:44 2023 kern.info kernel: [65495.694257] mt7530 mdio-bus:1f wan: Link is Down
Sun Oct 22 15:29:44 2023 daemon.notice netifd: wan (12279): udhcpc: received SIGTERM
Sun Oct 22 15:29:44 2023 daemon.notice netifd: wan (12279): udhcpc: unicasting a release of 100.105.221.10 to 100.64.0.1
Sun Oct 22 15:29:44 2023 daemon.notice netifd: wan (12279): udhcpc: sending release
Sun Oct 22 15:29:44 2023 daemon.notice netifd: wan (12279): udhcpc: entering released state
Sun Oct 22 15:29:44 2023 daemon.notice netifd: wan (12279): Command failed: ubus call network.interface notify_proto { âactionâ: 0, âlink-upâ: false, âkeepâ: false, âinterfaceâ: âwanâ } (Permission denied)
Sun Oct 22 15:29:44 2023 daemon.notice netifd: Interface âwanâ is now down
Sun Oct 22 15:29:44 2023 daemon.info avahi-daemon[5263]: Withdrawing address record for 100.105.221.10 on wan.
Sun Oct 22 15:29:44 2023 daemon.info avahi-daemon[5263]: Leaving mDNS multicast group on interface wan.IPv4 with address 100.105.221.10.
Sun Oct 22 15:29:44 2023 daemon.info avahi-daemon[5263]: Interface wan.IPv4 no longer relevant for mDNS.
Sun Oct 22 15:29:44 2023 daemon.warn dnsmasq[1]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sun Oct 22 15:29:44 2023 daemon.notice netifd: Interface âwanâ is disabled
Sun Oct 22 15:29:44 2023 kern.info kernel: [65495.890634] mt7530 mdio-bus:1f wan: configuring for phy/gmii link mode
Sun Oct 22 15:29:44 2023 kern.info kernel: [65495.898007] 8021q: adding VLAN 0 to HW filter on device wan
Sun Oct 22 15:29:44 2023 daemon.notice netifd: Interface âwanâ is enabled
Sun Oct 22 15:29:45 2023 user.notice mwan3[15564]: Execute ifdown event on interface wan (unknown)
Sun Oct 22 15:29:47 2023 daemon.notice netifd: Network device âwanâ link is up
Sun Oct 22 15:29:47 2023 daemon.notice netifd: Interface âwanâ has link connectivity
Sun Oct 22 15:29:47 2023 daemon.notice netifd: Interface âwanâ is setting up now
Sun Oct 22 15:29:47 2023 kern.info kernel: [65498.831864] mt7530 mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control off
Sun Oct 22 15:29:47 2023 daemon.notice netifd: wan (16111): udhcpc: started, v1.35.0
Sun Oct 22 15:29:47 2023 user.info mwan3track[12932]: Detect ifdown event on interface wan (wan)
Sun Oct 22 15:29:47 2023 daemon.notice netifd: wan (16111): udhcpc: broadcasting discover
Sun Oct 22 15:29:48 2023 user.notice firewall: Reloading firewall due to ifdown of wan ()
Sun Oct 22 15:29:48 2023 daemon.notice netifd: Network device âwanâ link is down
Sun Oct 22 15:29:48 2023 daemon.notice netifd: Interface âwanâ has link connectivity loss
Sun Oct 22 15:29:48 2023 kern.info kernel: [65499.585592] mt7530 mdio-bus:1f wan: Link is Down
Sun Oct 22 15:29:48 2023 daemon.notice netifd: wan (16111): udhcpc: received SIGTERM
Sun Oct 22 15:29:48 2023 daemon.notice netifd: wan (16111): udhcpc: entering released state
Sun Oct 22 15:29:48 2023 daemon.notice netifd: wan (16111): Command failed: ubus call network.interface notify_proto { âactionâ: 0, âlink-upâ: false, âkeepâ: false, âinterfaceâ: âwanâ } (Permission denied)
Sun Oct 22 15:29:48 2023 daemon.notice netifd: Interface âwanâ is now down
Sun Oct 22 15:29:48 2023 daemon.notice netifd: Interface âwanâ is disabled
Sun Oct 22 15:29:48 2023 kern.info kernel: [65499.847297] mt7530 mdio-bus:1f wan: configuring for phy/gmii link mode
Sun Oct 22 15:29:48 2023 kern.info kernel: [65499.854571] 8021q: adding VLAN 0 to HW filter on device wan
Sun Oct 22 15:29:48 2023 daemon.notice netifd: Interface âwanâ is enabled
Sun Oct 22 15:29:50 2023 user.notice route_policy: default_policy=0 mac_list=7C:50:79:00:C9:B3
Sun Oct 22 15:29:51 2023 daemon.notice netifd: Network device âwanâ link is up
Sun Oct 22 15:29:51 2023 daemon.notice netifd: Interface âwanâ has link connectivity
Sun Oct 22 15:29:51 2023 daemon.notice netifd: Interface âwanâ is setting up now
Sun Oct 22 15:29:51 2023 kern.info kernel: [65502.787372] mt7530 mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control off
Sun Oct 22 15:29:51 2023 daemon.notice netifd: wan (16483): udhcpc: started, v1.35.0
Sun Oct 22 15:29:51 2023 daemon.notice netifd: wan (16483): udhcpc: broadcasting discover
Sun Oct 22 15:29:52 2023 daemon.notice netifd: Network device âwanâ link is down
Sun Oct 22 15:29:52 2023 daemon.notice netifd: Interface âwanâ has link connectivity loss
Sun Oct 22 15:29:52 2023 kern.info kernel: [65503.541157] mt7530 mdio-bus:1f wan: Link is Down
Sun Oct 22 15:29:52 2023 daemon.notice netifd: wan (16483): udhcpc: received SIGTERM
Sun Oct 22 15:29:52 2023 daemon.notice netifd: wan (16483): udhcpc: entering released state
Sun Oct 22 15:29:52 2023 daemon.notice netifd: wan (16483): Command failed: ubus call network.interface notify_proto { âactionâ: 0, âlink-upâ: false, âkeepâ: false, âinterfaceâ: âwanâ } (Permission denied)
Sun Oct 22 15:29:52 2023 daemon.notice netifd: Interface âwanâ is now down
Sun Oct 22 15:29:52 2023 daemon.notice netifd: Interface âwanâ is disabled
Sun Oct 22 15:29:52 2023 kern.info kernel: [65503.821629] mt7530 mdio-bus:1f wan: configuring for phy/gmii link mode
Sun Oct 22 15:29:52 2023 kern.info kernel: [65503.829363] 8021q: adding VLAN 0 to HW filter on device wan
Sun Oct 22 15:29:52 2023 daemon.notice netifd: Interface âwanâ is enabled
Sun Oct 22 15:29:53 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.162 60:14:66:fe:5f:9b
Sun Oct 22 15:29:53 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.162 60:14:66:fe:5f:9b K83V
Sun Oct 22 15:29:54 2023 user.notice mwan3[16543]: Execute ifdown event on interface wan (unknown)
Sun Oct 22 15:29:54 2023 user.info mwan3track[12932]: Detect ifdown event on interface wan (wan)
Sun Oct 22 15:29:54 2023 user.notice mwan3track[12932]: Interface wan (wan) is offline
Sun Oct 22 15:29:55 2023 daemon.notice netifd: Network device âwanâ link is up
Sun Oct 22 15:29:55 2023 daemon.notice netifd: Interface âwanâ has link connectivity
Sun Oct 22 15:29:55 2023 daemon.notice netifd: Interface âwanâ is setting up now
Sun Oct 22 15:29:55 2023 kern.info kernel: [65506.685720] mt7530 mdio-bus:1f wan: Link is Up - 1Gbps/Full - flow control off
Sun Oct 22 15:29:55 2023 daemon.notice netifd: wan (17089): udhcpc: started, v1.35.0
Sun Oct 22 15:29:55 2023 daemon.notice netifd: wan (17089): udhcpc: broadcasting discover
Sun Oct 22 15:29:55 2023 user.notice firewall: Reloading firewall due to ifdown of wan ()
Sun Oct 22 15:29:57 2023 user.notice route_policy: default_policy=0 mac_list=7C:50:79:00:C9:B3
Sun Oct 22 15:29:58 2023 daemon.notice netifd: wan (17089): udhcpc: broadcasting discover
Sun Oct 22 15:29:59 2023 daemon.notice netifd: wan (17089): udhcpc: broadcasting select for 100.105.221.10, server 100.64.0.1
Sun Oct 22 15:29:59 2023 daemon.notice netifd: wan (17089): udhcpc: lease of 100.105.221.10 obtained from 100.64.0.1, lease time 300
Sun Oct 22 15:29:59 2023 daemon.info avahi-daemon[5263]: Joining mDNS multicast group on interface wan.IPv4 with address 100.105.221.10.
Sun Oct 22 15:29:59 2023 daemon.info avahi-daemon[5263]: New relevant interface wan.IPv4 for mDNS.
Sun Oct 22 15:29:59 2023 daemon.info avahi-daemon[5263]: Registering new address record for 100.105.221.10 on wan.IPv4.
Sun Oct 22 15:29:59 2023 daemon.notice netifd: Interface âwanâ is now up
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: using nameserver 1.1.1.1#53
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: using nameserver 8.8.8.8#53
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sun Oct 22 15:29:59 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sun Oct 22 15:29:59 2023 user.info mwan3track[12932]: Lost 6 ping(s) on interface wan (wan)
Sun Oct 22 15:30:00 2023 user.notice mwan3[17388]: Execute ifup event on interface wan (wan)
Sun Oct 22 15:30:01 2023 user.notice mwan3[17388]: Starting tracker on interface wan (wan)
Sun Oct 22 15:30:01 2023 user.notice mwan3track[12932]: Stopping mwan3track for interface âwanâ
Sun Oct 22 15:30:05 2023 user.info mwan3rtmon[4693]: Detect rtchange event.
Sun Oct 22 15:30:06 2023 user.notice firewall: Reloading firewall due to ifup of wan (wan)
Sun Oct 22 15:30:08 2023 user.notice route_policy: default_policy=0 mac_list=7C:50:79:00:C9:B3
Sun Oct 22 15:32:29 2023 daemon.notice netifd: wan (17089): udhcpc: sending renew to server 100.64.0.1
Sun Oct 22 15:32:29 2023 daemon.notice netifd: wan (17089): udhcpc: lease of 100.105.221.10 obtained from 100.64.0.1, lease time 300
Sun Oct 22 15:34:59 2023 daemon.notice netifd: wan (17089): udhcpc: sending renew to server 100.64.0.1
Sun Oct 22 15:34:59 2023 daemon.notice netifd: wan (17089): udhcpc: lease of 100.105.221.10 obtained from 100.64.0.1, lease time 300
