lzkowa
October 5, 2022, 4:41pm
hey all!
so, I’m trying to setup adblock on my Beryl but I can’t for the life of me to make it work
apparently, all is well and I followed different tutorials here but it simply has to affect on the connection whatsoever
Here is my Adblock config:
I have only one domain just for the sake of testing
and here is my DNS config
as one can see, nothing special…
am I missing something?
I am running the latest firmware (3.215)
Uninstall from openwrt and reinstall from GL.iNet admin panel will be under plugins. Restart the router and turn on adguardhome. Next access adguardhome settings page and setup lists and DNS.
lzkowa
October 5, 2022, 4:56pm
3
wait, I’m confused…
that’s what I did in the first place, I installed adblock and luci-adblock from the gl.inet admin panel
I don’t have adguard installed…I thought that adblock is a lighter solution…am I wrong? do I really need adguard installed?
Thats my bad I misread,thought it was adguardhome
funfun
October 6, 2022, 11:25am
5
Do you have anything in the logs? I remember it took me a bit to get it working but afterwards it all “made sense”.
Try running it just with the steven black list. That includes most of the rest anyway, but I think you’ve got way to much.
Otherwise looked ok to me.
lzkowa
October 7, 2022, 4:23pm
7
thanks for the help, folks but nothing worked and I ended up going back to adguard, which takes beryl to the limit but whatever hahahaha
