Hello everyone!
I recently bought an MT-3000 (Beryl AX).
Since using the router, I have at least 3 to 4 wifi disconnections per day.
I test with RJ-45 cable → The same.
My network.
Internet — Firewall (opnsense) — MT-3000 — WIFI and Cable connection
Does anyone else have the same problem?
check the kernel and system logs and share the relevant ones so that we pinpoint the issue.
I found eth0 interface disconnects in the log!!! Why has the MT-3000 lost the network. I tested with the old router, no problem
[26281.196215] 7981@C15L3,PeerPairMsg4Action() 6639: ===>Receive msg 4
[26281.207975] 7981@C15L2,PeerPairMsg4Action() 7002: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from 14:7d:da:e4:19:de
[26281.207975]
[26330.762819] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[26330.826659] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[26334.921785] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[26334.930247] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[26413.750193] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[26413.813855] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[26417.909156] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[26417.917621] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready[26281.196215] 7981@C15L3,PeerPairMsg4Action() 6639: ===>Receive msg 4
[26281.207975]
another log
[27709.522833] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[27709.542431] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
[27713.649814] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[27713.658287] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Is it connected to your upstream router using an Ethernet cable from the WAN port? If yes, try to disable flow control on the open sense for the connected interface and test again? If it still gets disconnected then change the Ethernet cable.
Thanks @SpitzAX3000, i replace my old network cable by network cable include in MT-3000 box.
It’s work fine !
How is it possible for a cable to cause so many problems?
I suspected that from the flow control errors. Flow Control is a mechanism used by the Ethernet data link protocol.
So if you see errors related to an Ethernet, you either look at the Ethernet settings between two devices or suspect that the cable has some damage.
I thought the problem was solved, but it’s not
I still have the flow control issue on the wan interface (eth0) which is connected to my opnsense firewall. I did disable flow control on the firewall.
Can we disable flow control on the MT-3000?
Login to LuCi → startup → under rc.local
ethtool -A eth0 autoneg off rx off tx off
/etc/init.d/network restart
The reboot and login from ssh to verify it:
ethtool -a eth0
If the package is not there you can install it.
