Hello everyone,
I am using MT-300A router with openwrt-mt300a-2.265.bin firmware
Can I add WireGuard client to it?
Hello everyone,
Truly sorry, the firmware update for MT300A has ended on 2019-12-17, means it already EoL.
I just checked the firmware download center. This model has a v3.x beta firmware. Please try to update to this firmware version to see if it has WireGuard client.
This old firmware is still working fine ![]()
Ok, thanks for the tip, I'll be trying that out.
Yes, WireGuard works well in firmware openwrt-mt300a-3.100-1217.bin, thank you.
But, unfortunately, it has a big drawback, described here.
We are very sorry about this, since the MT300A is relatively old, and the hardware cannot support v4 firmware updates, so it can only be maintained use on v3 firmware.
Maybe a new GL router will work better and good experience.
