I bought my GL-MT300A router around 6 weeks ago and have been bringing it travelling with me china/hong kong/india however I’m having multiple issues hoping you can help. When the device works its pretty awesome. however the wifi is constantly dropping, when it does I need to reboot the device to reconnect and it works for a period of time. Also my password stop working randomly, it says incorrect wifi password when it is correct! if I reboot the device it works so I’m not sure the problem. Another problem which is happening frequently is the local site http://192,168,8,1 stops working and I need to do a hard reset otherwise I cant access the interface to configure. Any clue why? I’ve tried to do a firmware upgrade with the same version, and also many factory resets.
any help is greatly appreciated.
