I just updated my firmware and this router no longer responds.
I’ve even done a factory reset (hold down reset while applying power) and plugged directly into the LAN port
I get no DHCP response.
Ok I got it running again.
Holding down reset while powering up and I used the ethernet cable
Browser connect to 192.168.1.1 and upload the image
It’s running again. There may be an issue with older firmware loading this update. I know the download was interrupted and it resumed, that might have something to do with it but the signature check had succeeded when it finished the download.
sometimes it happens for no reason.
