Anyone else having IPv4 problems with their MT-6000 - Flint 2 (firmware 4.11.1 beta) and Sky FTTP which I think are due to their MAP-T system.
Router randomly keeps acquiring new "public" IPv4 address in the 100.x.x.x range which I think is a sign of MAP-T (like CGNAT) as work and I loose all IPv4 access, i.e. clients that can't do IPv6 can no longer access the internet. Mostly a single router reboot persuades it to claim a 94.x.x.x or 90.x.x.x etc IP and IPv4 access is restored.
I also have this issue when Sky renews my public facing IP roughly every 56 days and if I am not around the Flint2 router will fail to re-negotiate a new IP and stay in the 100.x.x.x range. I think it is rubbish that Sky operate behind both CG-NAT & MAP-T protocols and unless we can find a fix I will be leaving to an ISP that doesn't use these silly systems, such as BT or Plusnet.
I have also come across a potential work-around but I've not tested it yet and wanted to post it here for someone at GL-iNET to confirm this is the best work-around for us?
To prevent this issue from happening when you aren't around, you can create a lightweight watchdog script on the Flint 2 that tests for internet connectivity and auto-renews the WAN connection if the connection drops after an IP change.
SSH into your Flint 2.
Create a script file in an appropriate persistent directory:
bash
vi /etc/config/wan_watchdog.sh
Use code with caution.
Paste the following automated script (press i to enter insert mode in vi):
bash
#!/bin/sh
# Ping a stable public DNS server to test connectivity
if ! ping -c 2 -W 3 8.8.8.8 > /dev/null 2>&1; then
logger "WAN Watchdog: Internet disconnected (possible IP change). Forcing WAN renew..."
ifup wan
fi
Save and exit (press ESC, then type :wq and hit Enter).
Make the script executable:
bash
chmod +x /etc/config/wan_watchdog.sh
Add it to the system router scheduler (Cron) so it runs every 2 to 5 minutes:
I've used the Sky Broadband VPN Configuration form here Homepage to get them to hopefully apply the Disable MAP-T Profile to my connection so it doesn't try to force MAP-T usage on connection as I don't think the default Flint 2 (MT-6000) is able to support MAP-T. I have seen some other posts on here with people struggling to get it to work on a Flint 3 but I have never seen a setup guide to get a Flint 2 to work with MAP-T.
