MT-6000 Flint 2 USB HDD sleep mode?
allo is there the possibility of putting a connected USB HDD into sleep mode (for example after 5 minutes) when it is not needed?
It does sleep afaik as long as youre not interacting with it.
Well, not really.
It rotates non-stop (which it shouldn't and doesn't need)
It doesn't matter whether I leave them alone for 5 minutes or 5 hours. Even when I'm not at home the HDD spins.
The controller needs to support the sleep command. For USB this isn't the case, mostly.
The HDD is only 2 years old.
It would be a good point to take this under
"Applications - Network Storage".
It just has to:
opkg update && opkg install luci-app-hd-idle
To be installed + restart. Then in Luci - under Services set the time when it should go off and that's it.
This means the disk only runs when it is needed.
Collected and be evaluated inside to determine, thanks.
i am also using it and is very practical. As you maybe dont need 24/7 the usb hdd is good to put him to sleep. Will be good to have something the same in the Network Storage options.
