MT-6000 WAN Drops
I just got my MT-6000 and though the default software and OpenWRT works fine, my WAN / PPPoE internet connection drops off every so often for a minute or two.
it is really annoying. My other openwrt router works fine but it seems the issue is with the MT-6000.
I've seen others with similar issues but not any definitive fix.
Does anyone know how to fix this?
I can post logs etc should they be required.
Please share any details (like used modem, firmware) and log files. See How to get support quickly
Please PM me the syslog, how the phenomenon of the GL GUI is?
Thanks guys.
I can't seem to find the option to PM you. Can you please advise?
the WAN interface seems to down/up with 3-4 times from the syslog, probably it is compatibility issue of the Ethernet speed rate negotiation. Please can try these in the SSH of the router:
ifconfig
//Confirm which one interface is the WAN, say if the eth1 is the WAN and fixed 1000Mbps:
ethtool -s eth1 autoneg off
ethtool -s eth1 speed 1000
