MT-6000 wan speed drops to 100Mbps after upgrade 4.9.1
When there’s an upgrade for my router, I usually upgrade immediate.
So, the same for the upgrade v4.9.1
Everything went well and after using it for some hours, I wanted to download a large file and noticed the download speed was not as high as normal.
I performed a speedtest.net and my internet speed was about 100Mbps while normally it shows 1800Mbps.
Because I use a mediaconverter before the MT-6000, I plugged the fiber in the modem of the provider and after connection, I got a speed of 1800Mbps.
Re plugged the fibre in the media converter and flashed the MT-6000 back to 4.9.0 and yes, the speed was back at 1800Mbps.
It seems the v4.9.1 caps my wan speed to about 100Mbps.
Is this a bug or did I miss some settings?
Greetings Tom
