Mt1300 has only 32mb of internal Memory and they can finish quickly. Is it possible to move the plugins to the sd card? Or is it possible to use an SD card to increase the internal memory space?
Yes it is called exroot.
It should be easy.
Format your SD to ext4
Plug in the router
Go to luci and change mount point for /overlay
hi,
the router runs openwrt and the internet is full of how-to guides.
https://www.pcsuggest.com/configuring-extroot-with-openwrt-on-tp-link-mr-3220/
Does this work on the SlateAX too?
