MT1300 (Beryl) now has 4.x firmware in beta (4.1.0 beta 3 is out)
We will try to refactor the network storage module to install it on older products. But not in version 4.3.2.
I took my Beryl traveling and found that my Sonos Roam was not seen by my Sonos app. Is there a confit change I need to make? This worked fine in v3.
Is it possible to get additional applications unlocked (network storage, adGuard, Parental Control, Tailscale) for those of us that run 4.3.2. with extroot?
How to add official openwrt feeds for missing packages?
They were removed on older products not because of storage space, but because the CPU couldn’t handle the load.
Is it possible to get them back for experimental use?
Network Storage is scheduled to be rebuilt and will be included in the official firmware when the rebuilds are complete.
No other features are planned for adaptation.
You should be able to install AdGuard Home by yourself.
@jjross I would check to see what port your Sonos app uses to connect to your Sonos Roam alot of times the port apps use is also used by something else preventing their default communication when traveling.
There shouldn’t be any firewall rules blocking inter-LAN communication between devices so Im not sure that’s the issue.
The Sonos forum seems to indicate that they use SSDP for discovery so perhaps multicast traffic is being blocked or dropped on wifi.
I am running the Mudi and really like the V4 beta so far, is there away to add Network Storage back? I use that for device transfers and for storage on the go.
We added it to the repository. You can install it in plug-ins.
