I’m using MT1300 as a travel router. I am able to use it as a router when connected to hotel LAN. However every 45 seconds or so, there’d be a blip in ping time. If I ping the router’s IP address, I’d see a timeout repeating every 45 seconds.
Has anyone encountered this issue and find a fix? my MT1300 is now on firmware 3.203 (2021-08-09 16:28:30)
@alzhao
yes directly connected using ethernet cable to the hotel ethernet using WAN port.
There’s no captive portal on the WAN interface and the timeout happens every 45 seconds continuously, it’s evident when I ping the router on my mac (and my ipad and iphone) from wifi, timeout every 45 seconds or so.
ssh into the router running logread -f shows nothing.
BTW, using the OOPS firmware that you posted seems to remediate the issue, I suspect it may be a WIFI driver issue in the current stable firmware?
I get the same issue over wifi.
I’ve just updated to the latest beta firmware 3.2.12 (released 1 march 2022) and I get exactly the same issues.
No difference for 2.4 or 5hz.
Any other suggestions? It makes video calls awful.
I had this problem with the previous firmware as well and was hoping the new firmware resolve it
Doesnt matter what sort of device I connect with. An example below. Also doesn’t matter which wifi frequency.
64 bytes from 192.168.8.1: icmp_seq=26 ttl=64 time=2.987 ms
64 bytes from 192.168.8.1: icmp_seq=27 ttl=64 time=1.705 ms
64 bytes from 192.168.8.1: icmp_seq=28 ttl=64 time=50.693 ms
Request timeout for icmp_seq 29
Request timeout for icmp_seq 30
Request timeout for icmp_seq 31
Request timeout for icmp_seq 32
64 bytes from 192.168.8.1: icmp_seq=33 ttl=64 time=2.066 ms
64 bytes from 192.168.8.1: icmp_seq=34 ttl=64 time=2.840 ms
64 bytes from 192.168.8.1: icmp_seq=35 ttl=64 time=2.785 ms
Is there any other way to get a more detailed diagnostic to share?
I have just found the same as the other poster on the other thread suggested
If I set the router up to connect as a wifi repeater and then I connect via wifi from my devices then there is no dropouts in connection! Only when using wired connection from router to get internet access is there dropouts!
