I’ve had the Beryl for quite some time now, and use it as a travel VPN router. Until last night. everything was fine. I am staying at a new hotel, and every 30 minutes to 1 hour, it reboots itself.
I’m not hugely techy, and not sure how top get logs and such. But I am on the most up to date firmware if that helps.
Any feedback or suggestions, or request for further information, would be appreciated.
I’ve been having this same problem. It’s been pretty stable until I connect and enable the OpenVPN client and the VPN policy. Then it will start randomly rebooting.
@elorimer Thanks for sharing the link. But when I go to the page, it’s just white with the Gl-inet logo and nothing else. What am I missing? Do you see something else when you go to that page?
Edit: Ah, OK. I see there is a new place for downloading firmware now. I’ll go ahead and download from there!
I’ve got the same problem with an average of two restarts per day on a quite standard configuration. My device is connected through a LAN cable and my PC is also connected to the device the same way. I have all the functionalities turned off with the sole exception for a 5Ghz WiFi to which I connect my phone. My firmware version is 3.215 (the latest stable as today).
