when I try and upgrade my MT1300 firmware , either from the WEB UI or the download page I get the .bin file
both ways get verification fail , and local tells me it is the incorrect firmware format
reading a post on the AR750 it says that the .tar file is needed - and I can not find a .tar on the MT1300 downloads page
alzhao
March 3, 2022, 10:32am
2
Can you verify the md5 hash of the firmware file you download?
MT1300 only has .bin firmware.
MD5 ac89bf826792e58a681d58521569b677
limbot
March 4, 2022, 1:01am
4
Ahh , I think you need to upgrade to 3.105 and then upgrade to 3.211. It was a known “glitch” a while ago.
@alzhao appears that 3.105 isn’t on the download site, may need to get someone to upload for those still on much older firmwares.
Alternatively you could download 3.211 and reload via uboot .
thanks for the answer - just need a download of 3.105
is there any way to ping a GL-inet tech and ask for it to be added to their download page ?
limbot
March 4, 2022, 1:47am
6
I’ve tagged in Alfie in the previous post and I’m sure he’ll fix once he sees alternatively you could also perhaps send an email to the help desksupport(at)gl-inet.com and see if someone picks the job up faster.
alzhao
March 4, 2022, 2:27am
7
3.104 cannot upgrade to 3.203 only happens on Slate AR750s I think. Not MT1300.
limbot
March 4, 2022, 3:58am
8
Ahh sorry @alzhao and @amtowghng bum steer from me
well - sorry for wasting your time - but for some reason I thought I owned a Beryl
under instruction from Gl-inet I inspected the label - GL-AR750S
whoops - cringe
