Greetings, running 3.215 on MT1300 Beryl, setup wireguard profile to connect to my home network.
In the wireguard profile, I have remote DNS setup for 192.168.0.115 I run on the remote network with host mappings.
If I connect to the wireguard server from e.g. LTE, I can connect to the hostnames via 192.168.0.115 DNS server without a problem.
If I connect to the wireguard server from MT1300, the DNS server is still the MT1300’s one, not the remote network one, so I cannot connect to the hostnames via DNS entries.
I fixed it via editing hosts file on MT1300, which works, but that’s not too elegant. Any idea why the DNS requests always come to MT1300 despite DNS entry in the WG profile saying otherwise?
Thanks, appreciate it, I looked a bit into it, the DNS routing in OpenWRT is a black magic, ton of options to configure dnsmasq, then also the DHCP server what it gives out as DNS (there’s so called "option 6, when you can basically instruct DHCP in OpenWRT to hand out 3rd party servers, not its default router localhost), when it uses forwarded DNS, when you define a different upstream one, when it excludes e.g. “.lan” domains.
I think I’ll handle this OK after ton of experimentation, thanks for your offer to help!
What’s more interesting is that if you go to the router’s diagnostics via LuCI, you’ll see that the router itself can’t resolve addresses on the WireGuard network, despite the DNS settings being in Automatic and the “DNS from WireGuard” being the proper address. The router just won’t use it, at all, ever.
If you set your client’s DNS server manually to the WireGuard server, it works perfectly.
