I am trying to flash my mt2500. I can get to the Uboot GUI, select the version file (using the file for version 4.1.1), upload the file, and then when I press the button to install the file the light on the mt2500 goes out and I get a screen that says UPDATE FAILED - Something went wrong during update.
Some users have had similar problems with Firefox, I suggest you try it with Google Chrome.
Google chrome did the trick, thank you.
