I have a fixed VDSL on the WAN connection - that gives speeds of 50mb/s
I have a 5G modem on a USB to LAN adaptor set as TETHERING - that’s gives speeds of 500mb/s
I have failover set with the priority of TETHERING then WAN
However it always connects via the VDSL WAN connection
On load balance it also always connects on the VDSL WAN
My connection never goes above 50mb/s unless I physically remove the WAN connection
Okay this is going to sound redundant because you’ve already clearly stated what you’ve done… but you have the Interface Priority adjusted per GL GUI → Network → Multi-WAN → Interface Priority → [drag to sort]?
What firmware version are you using? Is it the most recent stable release (GL GUI → System → Upgrade)?
I think I’m onto something but I’m still speculating. Can you ssh into your Burme 2 & post the output of cat /etc/config/network? I’m looking to see what’s set for the metric of your various interfaces.
Also if you could install LuCI & confim the version of OpenWrt @ its status page (GL GUI → System → Advanced Settings). Default pwd is same as the GL GUI, username root .
(Oh gawd, pastebin… next time could you just post directly into your response? You can format codeblocks by putting them between three ‘backticks’ on lines before & after the output (the key up buy the 1 key on the keyboard). It helps others follow along if they stumble on this thread for a similar issue)
Thanks for confirming the OWRT version.
There’s missing lines from that output. It should start w/
root@192.168.2.1's password:
BusyBox v1.33.2 (2023-07-06 05:09:44 UTC) built-in shell (ash)
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
OpenWrt 21.02-SNAPSHOT, r15812+879-46b6ee7ffc
root@GL-MT2500:~# echo "### begin ip routes ###" && ip route show && echo "### /
/ end of ip routes ###"
0.0.0.0/1 dev wgclient scope link
default via 192.168.1.254 dev eth0 proto static metric 10
default via 192.168.8.1 dev eth2 proto static src 192.168.8.100 metric 30
10.0.0.0/24 dev wgserver proto kernel scope link src 10.0.0.1
45.9.248.4 via 192.168.1.254 dev eth0 proto static metric 10
128.0.0.0/1 dev wgclient scope link
192.168.1.0/24 dev eth0 proto static scope link metric 10
192.168.2.0/24 dev br-lan proto kernel scope link src 192.168.2.1
192.168.8.0/24 dev eth2 proto static scope link metric 30
### // end of ip routes ###
root@GL-MT2500:~#
Okay, we’re going to need to adjust a couple of the metric values by editing the /etc/config/network . If you’re not comfortable w/ vi, the nano editor is far easier. opkg update && opkg install nano .
You want your tethering interface to be the primary Internet connection for your Multi-WAN setup while the Ethernet is also connected to your Burme 2's WAN port.
Issue
The Ethernet takes priority for all Internet connections in a Multi-WAN setup but the tethered device offers a faster connection. Interface Priority has been adjusted within the GL GUI -> Network -> Multi-WAN -> Interface Priority but does not seem to be honored/have an effect.
Diagnosis
Network configuration details for network interfaces are stored in the text file /etc/config/network
The Ethernet uses the wan network interface with a metric of 10. This sets its priority over any other interfaces.
The tethered device uses the tethering network interface with a metric of 30. Its higher value places it at a lower priority.
Proposed Resolution
Edit & save the /etc/config/network to set tethering's metric to 10 & wan's metric to 30.
nano /etc/config/network
Restart the networking system
service network reload or /etc/init.d/network reload
I did as you said and lost access to the internet
Both interfaces were showing red and failing ping tests
I put it back and they came back on
_______ ________ __
root@GL-MT2500:~# nano /etc/config/network
root@GL-MT2500:~# service network reload
root@GL-MT2500:~# ip route show
default via 192.168.8.1 dev eth2 proto static src 192.168.8.100 metric 10
default via 192.168.1.254 dev eth0 proto static metric 30
192.168.1.0/24 dev eth0 proto static scope link metric 30
192.168.8.0/24 dev eth2 proto static scope link metric 10
root@GL-MT2500:~#```
I had a VPN client running - that my PC wasn’t going through - but stopping the VPN and restarting has brought the PC back online with the new settings
Thanks for all the help - looks like its working - but still a bug I guess that you can’t do it through the glinet UI when it suggests you can.
