MT2500 op24
Hello everyone, is there an up-to-date version of openwrt for brume 23 or 24?
GL firmware of MT2500 still use closed-source codes, it has not updated to op23/op24.
There is an open-source firmware version which is vanilla OpenWRT:
https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/
...-sysupgrade.bin is the firmware which can be flash in webui or uboot.
will there be an official update to a higher version from glinet?
24.10-SNAPSHOT are available:
https://downloads.openwrt.org/releases/24.10-SNAPSHOT/targets/mediatek/filogic/
The 24.10-SNAPSHOT includes Luci web interface
So this is brand new? Anybody tested it yet? I thought Luci wasn’t normally included in snapshots?
OpenWRT 24.10 is currently in testing, this includes Luci as it's due to be the new stable version. So it'll go through the entire testing process like 23.05 did, so SNAPSHOT, RC, and then eventually stable.
Thanks, seems a bit of a breakthrough for Brume2 then.
immortal wrt - ImmortalWrt Firmware Selector
Runs well, did you also get the missing alternate gpt header?
I haven't tested it yet
What do you need that is not available on the current GL-iNEt firmware?
nftables for vless/xray
  • Kernel 6.6.60
  • Latest MaxLinear GPY211C drivers
  • Latest eMMC support
  • Latest arm-trusted-firmware-mediatek
Why do you need kernel 6.6.60 and latest GPY211C drivers, and latest etc, etc, etc?
I mean, do you have any bug or performance issue due to the current version of the Kernel and drivers?
@AceSpace gave a good reason on his answer.
Because the 21.02 SDK driver for the 2.5gb wan doesn't connect to my fibre ont after a reboot.
The Openwrt 24.10 driver does every single time.
All GL do is advise to swap the wan and lan ports.
Try in GL firmware, and how about the result:
rm /etc/hotplug.d/carrier/05-fix-mtk-sdk-eth
cat /etc/hotplug.d/carrier/05-fix-mtk-sdk-eth
[ -d /proc/mtketh ] || exit 0
model=$(cat /proc/gl-hw-info/model)
[ "$model" = "mt6000" ] || exit 0
[ "$ACTION" = "up" ] || exit 0
[ "$INTERFACE" = "eth1" ] || exit 0
do_fix() {
    rx0=$(cat /sys/class/net/eth1/statistics/rx_packets)
    sleep 8
    rx1=$(cat /sys/class/net/eth1/statistics/rx_packets)
    [ $rx0 -eq $rx1 ] || return 0
    logger "mtk-sdk eth halted detected, now reset it..."
    ifconfig eth1 down
    sleep 1
    ifconfig eth1 up
do_fix &
@bruce so the same fix is applied to MT2500, MT3000, X3000 and XE3000 due to an issue in the 21.02 SDK that GL-iNet is working from?
I checked this script only works in MT6000, but not sure if can it improve in MT2500 2.5Gbps issue with the closed-source driver, but just observe
Do I need to update the script to include MT2500 instead of MT6000 then?
If the router model is MT2500, seems this script will not take effect.
Try updating this script in the MT2500 to observe if it improves:
ppp.zip (2.5 KB)
1.unzip it, and get the ppp.sh
2. mv /lib/netifd/proto/ppp.sh /lib/netifd/proto/ppp.sh.bak
3. upload the new ppp.sh to /lib/netifd/proto/
