I am running node-red on an MT2500 to try and communicate with a device over Modbus RTU. I am using the USB port on the MT2500 with an adapter to communicate with the serial device, however I can’t seem to figure out what the path is for the USB port. Any help would be appreciated.
What type of serial chip do you have?
You may need to install a driver.
I’m using a waveshare USB to RS485 adapter, which uses FT232RL and SP485EEN chips.
You can try to install kmod-usb-serial-ftdi
Thank you, I will try that.
