MT300 (mango) and AR750 (creta) question/feedback
Hello all,
I noticed some "missing" options in mango and creta devices into the main gl.inet UI, present into the luci interface:
wpa2/wpa3 and wpa3 sae encryption: missing into glinet interface on mt300 (mango) but present in luci (ar750 ok)
EDIT: in mango - mt300 don't works at all although I select wpa3 in luci... maybe need a fix?
ap client isolation: missing in both mt300 (mango) and ar750 (creta) glinet ui but present in luci
it's possible to add this 2 useful feature in the glinet ui for the next update?
thanks
I will record these requests and submit them to the PM team for evaluation.
Regarding WPA3, it may not be used on MT300Nv2, because WPA3 needs to occupy a lot of CPU resources, and the CPU performance of MT300Nv2 may not be sufficient, and WPA3 may not be added in the later stage.
Thank you Bruce!
If it's possible on mango, I gladly use wpa3 "at my risk" :innocent:
regards!
