my device doesn’t connect with Tor app, and the log says:
/usr/sbin/tor restart
Error loading shared library libevent-2.0.so.5: No such file or directory (needed by /usr/sbin/tor)
Error relocating /usr/sbin/tor: evdns_set_log_fn: symbol not found
Error relocating /usr/sbin/tor: event_active: symbol not found
Error relocating /usr/sbin/tor: evdns_base_resolve_ipv4: symbol not found
Error relocating /usr/sbin/tor: event_config_set_flag: symbol not found
Error relocating /usr/sbin/tor: evdns_set_random_bytes_fn: symbol not found
Error relocating /usr/sbin/tor: event_base_loop: symbol not found
Error relocating /usr/sbin/tor: evdns_server_request_add_a_reply: symbol not found
Error relocating /usr/sbin/tor: event_get_version: symbol not found
I have installed Tor app gl-tor. I have two mt300-v2, and I confim you that with the first Tor it works, but with the second Tor it does not work.
I have also contacted support, but they didn’t respond.
No… I doesn’t it leak the dns, I cannot to install gl-tor app, because there isn’t free space on device, but I already installed gl-tor in other m300-v2, why?
