I try to be calm. And i am using it since 3 weeks now. I thought that my wifi problems will be gone after purchasing the MT300-V2. But it just gets worse. Random sudden problems. Switching from one to another wifi is risky. Now i am stuck after i switched from one AP to another. I have two APs. Normally i switch between these two (if i dare). Now it’s stuck as you see in the screenshot.
Using OpenVPN barely works too… but that’s another topic.
MT300 won’t connect to the internet through one of my APs. But when i connect my PC directly to the wifi AP. No problem. Internet is there.
Tell me what to do! I am willing to work on it. Even my frustration level is high already.
I just made a 3-seconds-reset. But still can’t connect. Here the syslog:
Tue Dec 4 17:24:21 2018 daemon.info dnsmasq[1904]: read /tmp/hosts/odhcpd - 1 addresses
Tue Dec 4 17:24:21 2018 daemon.info dnsmasq[1904]: read /tmp/hosts/dhcp.cfg02411c - 3 addresses
Tue Dec 4 17:24:23 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:24:27 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:24:43 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Network device 'ra0' link is down
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Network device 'apcli0' link is down
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Tue Dec 4 17:24:53 2018 daemon.notice netifd: wwan (1782): udhcpc: read error: Network is down, reopening socket
Tue Dec 4 17:24:53 2018 daemon.notice netifd: wwan (1782): udhcpc: received SIGTERM
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Interface 'lan' is now down
Tue Dec 4 17:24:53 2018 daemon.info odhcpd[1253]: Raising SIGUSR1 due to address change on br-lan
Tue Dec 4 17:24:53 2018 daemon.info dnsmasq[1904]: read /etc/hosts - 4 addresses
Tue Dec 4 17:24:53 2018 daemon.info dnsmasq[1904]: read /tmp/hosts/odhcpd - 0 addresses
Tue Dec 4 17:24:53 2018 daemon.info dnsmasq[1904]: read /tmp/hosts/dhcp.cfg02411c - 3 addresses
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Interface 'lan' is disabled
Tue Dec 4 17:24:53 2018 daemon.notice netifd: VLAN 'eth0.1' link is down
Tue Dec 4 17:24:53 2018 daemon.notice netifd: bridge 'br-lan' link is down
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Interface 'lan' has link connectivity loss
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Interface 'loopback' is now down
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Interface 'loopback' is disabled
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Network device 'lo' link is down
Tue Dec 4 17:24:53 2018 daemon.notice netifd: Interface 'loopback' has link connectivity loss
Tue Dec 4 17:24:54 2018 daemon.notice netifd: Interface 'wwan' is disabled
Tue Dec 4 17:24:54 2018 daemon.notice netifd: wan (1598): udhcpc: received SIGTERM
Tue Dec 4 17:24:54 2018 daemon.notice netifd: Interface 'wan' is now down
Tue Dec 4 17:24:54 2018 daemon.notice netifd: Interface 'wan6' is now down
Tue Dec 4 17:24:54 2018 daemon.notice netifd: Interface 'wan' is disabled
Tue Dec 4 17:24:54 2018 daemon.notice netifd: Interface 'wan6' is disabled
Tue Dec 4 17:24:54 2018 daemon.notice netifd: VLAN 'eth0.2' link is down
Tue Dec 4 17:24:54 2018 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Dec 4 17:24:54 2018 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Tue Dec 4 17:24:54 2018 daemon.notice netifd: Network device 'eth0' link is down
Tue Dec 4 17:24:55 2018 user.notice : Added device handler type: 8021ad
Tue Dec 4 17:24:55 2018 user.notice : Added device handler type: 8021q
Tue Dec 4 17:24:55 2018 user.notice : Added device handler type: macvlan
Tue Dec 4 17:24:55 2018 user.notice : Added device handler type: bridge
Tue Dec 4 17:24:55 2018 user.notice : Added device handler type: Network device
Tue Dec 4 17:24:55 2018 user.notice : Added device handler type: tunnel
Tue Dec 4 17:24:56 2018 daemon.info dnsmasq[1904]: exiting on receipt of SIGTERM
Tue Dec 4 17:25:01 2018 user.notice root: drv_ralink_cleanup
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'lan' is enabled
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'lan' is setting up now
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'lan' is now up
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'loopback' is enabled
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'loopback' is setting up now
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'loopback' is now up
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wan' is enabled
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wan6' is enabled
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wwan' is enabled
Tue Dec 4 17:25:02 2018 daemon.info odhcpd[1253]: Raising SIGUSR1 due to address change on br-lan
Tue Dec 4 17:25:02 2018 daemon.notice netifd: bridge 'br-lan' link is up
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'lan' has link connectivity
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Network device 'eth0' link is up
Tue Dec 4 17:25:02 2018 daemon.notice netifd: VLAN 'eth0.1' link is up
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Network device 'lo' link is up
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'loopback' has link connectivity
Tue Dec 4 17:25:02 2018 daemon.notice netifd: VLAN 'eth0.2' link is up
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wan' is setting up now
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wan6' has link connectivity
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wan6' is setting up now
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Network device 'apcli0' link is up
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wwan' has link connectivity
Tue Dec 4 17:25:02 2018 daemon.notice netifd: Interface 'wwan' is setting up now
Tue Dec 4 17:25:03 2018 daemon.notice netifd: wan (2818): udhcpc: started, v1.25.1
Tue Dec 4 17:25:03 2018 daemon.notice netifd: wwan (2820): udhcpc: started, v1.25.1
Tue Dec 4 17:25:03 2018 daemon.err odhcp6c[2817]: Failed to send DHCPV6 message to ff02::1:2 (Address not available)
Tue Dec 4 17:25:03 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:25:03 2018 daemon.notice netifd: wan (2818): udhcpc: sending discover
Tue Dec 4 17:25:03 2018 daemon.notice netifd: wwan (2820): udhcpc: sending discover
Tue Dec 4 17:25:03 2018 daemon.notice netifd: Network device 'ra0' link is up
Tue Dec 4 17:25:03 2018 daemon.notice netifd: Network device 'apcli0' link is down
Tue Dec 4 17:25:03 2018 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Tue Dec 4 17:25:03 2018 daemon.notice netifd: wwan (2820): udhcpc: read error: Network is down, reopening socket
Tue Dec 4 17:25:03 2018 daemon.notice netifd: wwan (2820): udhcpc: received SIGTERM
Tue Dec 4 17:25:04 2018 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Tue Dec 4 17:25:06 2018 daemon.notice netifd: wan (2818): udhcpc: sending discover
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: started, version 2.78 cachesize 150
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: DNS service limited to local subnets
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID loop-detect inotify
Tue Dec 4 17:25:06 2018 daemon.warn dnsmasq[2977]: warning: ignoring resolv-file flag because no-resolv is set
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq-dhcp[2977]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: using nameserver 8.8.4.4#53
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: using nameserver 8.8.8.8#53
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: using local addresses only for domain lan
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: read /etc/hosts - 4 addresses
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/odhcpd - 0 addresses
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/dhcp.cfg02411c - 5 addresses
Tue Dec 4 17:25:06 2018 daemon.info dnsmasq-dhcp[2977]: read /etc/ethers - 0 addresses
Tue Dec 4 17:25:09 2018 daemon.notice netifd: wan (2818): udhcpc: sending discover
Tue Dec 4 17:25:10 2018 daemon.info dnsmasq-dhcp[2977]: DHCPDISCOVER(br-lan) 2c:3a:e8:05:8e:eb
Tue Dec 4 17:25:10 2018 daemon.info dnsmasq-dhcp[2977]: DHCPOFFER(br-lan) 192.168.8.106 2c:3a:e8:05:8e:eb
Tue Dec 4 17:25:10 2018 daemon.info dnsmasq-dhcp[2977]: DHCPREQUEST(br-lan) 192.168.8.106 2c:3a:e8:05:8e:eb
Tue Dec 4 17:25:10 2018 daemon.info dnsmasq-dhcp[2977]: DHCPACK(br-lan) 192.168.8.106 2c:3a:e8:05:8e:eb Power2-13
Tue Dec 4 17:25:16 2018 daemon.info dnsmasq-dhcp[2977]: DHCPDISCOVER(br-lan) 5c:cf:7f:72:09:70
Tue Dec 4 17:25:16 2018 daemon.info dnsmasq-dhcp[2977]: DHCPOFFER(br-lan) 192.168.8.215 5c:cf:7f:72:09:70
Tue Dec 4 17:25:20 2018 daemon.info dnsmasq-dhcp[2977]: DHCPDISCOVER(br-lan) 2c:3a:e8:04:eb:35
Tue Dec 4 17:25:20 2018 daemon.info dnsmasq-dhcp[2977]: DHCPOFFER(br-lan) 192.168.8.176 2c:3a:e8:04:eb:35
Tue Dec 4 17:25:20 2018 daemon.info dnsmasq-dhcp[2977]: DHCPDISCOVER(br-lan) 5c:cf:7f:72:09:70
Tue Dec 4 17:25:20 2018 daemon.info dnsmasq-dhcp[2977]: DHCPOFFER(br-lan) 192.168.8.215 5c:cf:7f:72:09:70
Tue Dec 4 17:25:20 2018 daemon.info dnsmasq-dhcp[2977]: DHCPREQUEST(br-lan) 192.168.8.215 5c:cf:7f:72:09:70
Tue Dec 4 17:25:20 2018 daemon.info dnsmasq-dhcp[2977]: DHCPACK(br-lan) 192.168.8.215 5c:cf:7f:72:09:70 Ceiling-Light-14
Tue Dec 4 17:25:20 2018 daemon.info dnsmasq-dhcp[2977]: DHCPREQUEST(br-lan) 192.168.8.176 2c:3a:e8:04:eb:35
Tue Dec 4 17:25:20 2018 daemon.info dnsmasq-dhcp[2977]: DHCPACK(br-lan) 192.168.8.176 2c:3a:e8:04:eb:35 Power1-12
Tue Dec 4 17:26:38 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:26:38 2018 daemon.warn odhcpd[1253]: DHCPV6 SOLICIT IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:26:39 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:26:39 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:26:39 2018 daemon.warn odhcpd[1253]: DHCPV6 SOLICIT IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:26:40 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:26:40 2018 daemon.warn odhcpd[1253]: DHCPV6 REQUEST IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:26:40 2018 daemon.warn odhcpd[1253]: DHCPV6 SOLICIT IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:26:41 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:26:41 2018 daemon.warn odhcpd[1253]: DHCPV6 REQUEST IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:26:42 2018 daemon.info dnsmasq-dhcp[2977]: DHCPDISCOVER(br-lan) 00:21:5d:31:7f:06
Tue Dec 4 17:26:42 2018 daemon.info dnsmasq-dhcp[2977]: DHCPOFFER(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Tue Dec 4 17:26:42 2018 daemon.info dnsmasq[2977]: read /etc/hosts - 4 addresses
Tue Dec 4 17:26:42 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/odhcpd - 1 addresses
Tue Dec 4 17:26:42 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/dhcp.cfg02411c - 5 addresses
Tue Dec 4 17:26:42 2018 daemon.info dnsmasq-dhcp[2977]: read /etc/ethers - 0 addresses
Tue Dec 4 17:26:42 2018 daemon.info dnsmasq-dhcp[2977]: DHCPREQUEST(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Tue Dec 4 17:26:42 2018 daemon.info dnsmasq-dhcp[2977]: DHCPACK(br-lan) 192.168.8.118 00:21:5d:31:7f:06 DESKTOP-V9P3K86
Tue Dec 4 17:26:43 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:26:47 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:27:09 2018 daemon.info dnsmasq-dhcp[2977]: DHCPREQUEST(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Tue Dec 4 17:27:09 2018 daemon.info dnsmasq-dhcp[2977]: DHCPACK(br-lan) 192.168.8.118 00:21:5d:31:7f:06 DESKTOP-V9P3K86
Tue Dec 4 17:27:09 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:27:10 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:27:10 2018 daemon.warn odhcpd[1253]: DHCPV6 CONFIRM IA_NA from 000100012167358700e04c680f62 on br-lan: not on-link fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:27:10 2018 daemon.warn odhcpd[1253]: DHCPV6 SOLICIT IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:27:10 2018 daemon.info dnsmasq[2977]: read /etc/hosts - 4 addresses
Tue Dec 4 17:27:10 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/odhcpd - 0 addresses
Tue Dec 4 17:27:10 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/dhcp.cfg02411c - 5 addresses
Tue Dec 4 17:27:10 2018 daemon.info dnsmasq-dhcp[2977]: read /etc/ethers - 0 addresses
Tue Dec 4 17:27:11 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:27:11 2018 daemon.warn odhcpd[1253]: DHCPV6 REQUEST IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:27:11 2018 daemon.info dnsmasq[2977]: read /etc/hosts - 4 addresses
Tue Dec 4 17:27:11 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/odhcpd - 1 addresses
Tue Dec 4 17:27:11 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/dhcp.cfg02411c - 5 addresses
Tue Dec 4 17:27:11 2018 daemon.info dnsmasq-dhcp[2977]: read /etc/ethers - 0 addresses
Tue Dec 4 17:27:13 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Network device 'ra0' link is down
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Interface 'lan' is now down
Tue Dec 4 17:27:16 2018 daemon.info odhcpd[1253]: Raising SIGUSR1 due to address change on br-lan
Tue Dec 4 17:27:16 2018 daemon.info dnsmasq[2977]: read /etc/hosts - 4 addresses
Tue Dec 4 17:27:16 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/odhcpd - 0 addresses
Tue Dec 4 17:27:16 2018 daemon.info dnsmasq[2977]: read /tmp/hosts/dhcp.cfg02411c - 5 addresses
Tue Dec 4 17:27:16 2018 daemon.info dnsmasq-dhcp[2977]: read /etc/ethers - 0 addresses
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Interface 'lan' is disabled
Tue Dec 4 17:27:16 2018 daemon.notice netifd: VLAN 'eth0.1' link is down
Tue Dec 4 17:27:16 2018 daemon.notice netifd: bridge 'br-lan' link is down
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Interface 'lan' has link connectivity loss
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Interface 'loopback' is now down
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Interface 'loopback' is disabled
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Network device 'lo' link is down
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Interface 'loopback' has link connectivity loss
Tue Dec 4 17:27:16 2018 daemon.notice netifd: Interface 'wwan' is disabled
Tue Dec 4 17:27:17 2018 daemon.notice netifd: wan (2818): udhcpc: received SIGTERM
Tue Dec 4 17:27:17 2018 daemon.notice netifd: Interface 'wan' is now down
Tue Dec 4 17:27:17 2018 daemon.notice netifd: Interface 'wan6' is now down
Tue Dec 4 17:27:17 2018 daemon.notice netifd: Interface 'wan' is disabled
Tue Dec 4 17:27:17 2018 daemon.notice netifd: Interface 'wan6' is disabled
Tue Dec 4 17:27:17 2018 daemon.notice netifd: VLAN 'eth0.2' link is down
Tue Dec 4 17:27:17 2018 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Dec 4 17:27:17 2018 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Tue Dec 4 17:27:17 2018 daemon.notice netifd: Network device 'eth0' link is down
Tue Dec 4 17:27:18 2018 user.notice : Added device handler type: 8021ad
Tue Dec 4 17:27:18 2018 user.notice : Added device handler type: 8021q
Tue Dec 4 17:27:18 2018 user.notice : Added device handler type: macvlan
Tue Dec 4 17:27:18 2018 user.notice : Added device handler type: bridge
Tue Dec 4 17:27:18 2018 user.notice : Added device handler type: Network device
Tue Dec 4 17:27:18 2018 user.notice : Added device handler type: tunnel
Tue Dec 4 17:27:24 2018 user.notice root: drv_ralink_cleanup
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'lan' is enabled
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'lan' is setting up now
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'lan' is now up
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'loopback' is enabled
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'loopback' is setting up now
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'loopback' is now up
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wan' is enabled
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wan6' is enabled
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wwan' is enabled
Tue Dec 4 17:27:25 2018 daemon.info odhcpd[1253]: Raising SIGUSR1 due to address change on br-lan
Tue Dec 4 17:27:25 2018 daemon.notice netifd: bridge 'br-lan' link is up
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'lan' has link connectivity
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Network device 'eth0' link is up
Tue Dec 4 17:27:25 2018 daemon.notice netifd: VLAN 'eth0.1' link is up
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Network device 'lo' link is up
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'loopback' has link connectivity
Tue Dec 4 17:27:25 2018 daemon.notice netifd: VLAN 'eth0.2' link is up
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wan' is setting up now
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wan6' has link connectivity
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wan6' is setting up now
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Network device 'apcli0' link is up
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wwan' has link connectivity
Tue Dec 4 17:27:25 2018 daemon.notice netifd: Interface 'wwan' is setting up now
Tue Dec 4 17:27:26 2018 daemon.notice netifd: wwan (4027): udhcpc: started, v1.25.1
Tue Dec 4 17:27:26 2018 daemon.notice netifd: wan (4030): udhcpc: started, v1.25.1
Tue Dec 4 17:27:26 2018 daemon.info dnsmasq[2977]: exiting on receipt of SIGTERM
Tue Dec 4 17:27:26 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:27:26 2018 daemon.notice netifd: wwan (4027): udhcpc: sending discover
Tue Dec 4 17:27:26 2018 daemon.notice netifd: wan (4030): udhcpc: sending discover
Tue Dec 4 17:27:27 2018 daemon.notice netifd: Network device 'ra0' link is up
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: started, version 2.78 cachesize 150
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: DNS service limited to local subnets
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID loop-detect inotify
Tue Dec 4 17:27:27 2018 daemon.warn dnsmasq[4082]: warning: ignoring resolv-file flag because no-resolv is set
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq-dhcp[4082]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Tue Dec 4 17:27:27 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:27:27 2018 daemon.warn odhcpd[1253]: DHCPV6 SOLICIT IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: using nameserver 8.8.4.4#53
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: using nameserver 8.8.8.8#53
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: using local addresses only for domain lan
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: read /etc/hosts - 4 addresses
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/odhcpd - 0 addresses
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/dhcp.cfg02411c - 0 addresses
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq-dhcp[4082]: read /etc/ethers - 0 addresses
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq-dhcp[4082]: DHCPREQUEST(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Tue Dec 4 17:27:27 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:27:27 2018 daemon.info dnsmasq-dhcp[4082]: DHCPACK(br-lan) 192.168.8.118 00:21:5d:31:7f:06 DESKTOP-V9P3K86
Tue Dec 4 17:27:27 2018 daemon.notice netifd: Network device 'apcli0' link is down
Tue Dec 4 17:27:27 2018 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Tue Dec 4 17:27:27 2018 daemon.notice netifd: wwan (4027): udhcpc: read error: Network is down, reopening socket
Tue Dec 4 17:27:27 2018 daemon.notice netifd: Network device 'apcli0' link is up
Tue Dec 4 17:27:27 2018 daemon.notice netifd: Interface 'wwan' is setting up now
Tue Dec 4 17:27:27 2018 daemon.notice netifd: wwan (4027): udhcpc: received SIGTERM
Tue Dec 4 17:27:27 2018 daemon.notice netifd: Interface 'wwan' is now down
Tue Dec 4 17:27:27 2018 daemon.notice netifd: Interface 'wwan' is disabled
Tue Dec 4 17:27:27 2018 daemon.notice netifd: Interface 'wwan' is enabled
Tue Dec 4 17:27:27 2018 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Tue Dec 4 17:27:28 2018 daemon.notice netifd: wwan (4168): udhcpc: started, v1.25.1
Tue Dec 4 17:27:28 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:27:28 2018 daemon.warn odhcpd[1253]: DHCPV6 REQUEST IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:27:28 2018 daemon.info dnsmasq[4082]: read /etc/hosts - 4 addresses
Tue Dec 4 17:27:28 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/odhcpd - 1 addresses
Tue Dec 4 17:27:28 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/dhcp.cfg02411c - 3 addresses
Tue Dec 4 17:27:28 2018 daemon.info dnsmasq-dhcp[4082]: read /etc/ethers - 0 addresses
Tue Dec 4 17:27:28 2018 daemon.notice netifd: wwan (4168): udhcpc: sending discover
Tue Dec 4 17:27:28 2018 daemon.notice procd: /etc/init.d/network: uci: Entry not found
Tue Dec 4 17:27:29 2018 daemon.notice netifd: wan (4030): udhcpc: sending discover
Tue Dec 4 17:27:30 2018 daemon.info dnsmasq-dhcp[4082]: DHCPDISCOVER(br-lan) 5c:cf:7f:72:09:70
Tue Dec 4 17:27:30 2018 daemon.info dnsmasq-dhcp[4082]: DHCPOFFER(br-lan) 192.168.8.215 5c:cf:7f:72:09:70
Tue Dec 4 17:27:30 2018 daemon.info dnsmasq-dhcp[4082]: DHCPREQUEST(br-lan) 192.168.8.215 5c:cf:7f:72:09:70
Tue Dec 4 17:27:30 2018 daemon.info dnsmasq-dhcp[4082]: DHCPACK(br-lan) 192.168.8.215 5c:cf:7f:72:09:70 Ceiling-Light-14
Tue Dec 4 17:27:31 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:27:31 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:27:31 2018 daemon.warn odhcpd[1253]: DHCPV6 CONFIRM IA_NA from 000100012167358700e04c680f62 on br-lan: not on-link fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:27:31 2018 daemon.warn odhcpd[1253]: DHCPV6 SOLICIT IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:27:31 2018 daemon.notice netifd: wwan (4168): udhcpc: sending discover
Tue Dec 4 17:27:31 2018 daemon.info dnsmasq[4082]: read /etc/hosts - 4 addresses
Tue Dec 4 17:27:31 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/odhcpd - 0 addresses
Tue Dec 4 17:27:31 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/dhcp.cfg02411c - 3 addresses
Tue Dec 4 17:27:31 2018 daemon.info dnsmasq-dhcp[4082]: read /etc/ethers - 0 addresses
Tue Dec 4 17:27:32 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:27:32 2018 daemon.warn odhcpd[1253]: DHCPV6 REQUEST IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:27:32 2018 daemon.info dnsmasq[4082]: read /etc/hosts - 4 addresses
Tue Dec 4 17:27:32 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/odhcpd - 1 addresses
Tue Dec 4 17:27:32 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/dhcp.cfg02411c - 3 addresses
Tue Dec 4 17:27:32 2018 daemon.info dnsmasq-dhcp[4082]: read /etc/ethers - 0 addresses
Tue Dec 4 17:27:32 2018 daemon.notice netifd: wan (4030): udhcpc: sending discover
Tue Dec 4 17:27:33 2018 daemon.info dnsmasq-dhcp[4082]: DHCPDISCOVER(br-lan) 2c:3a:e8:05:8e:eb
Tue Dec 4 17:27:33 2018 daemon.info dnsmasq-dhcp[4082]: DHCPOFFER(br-lan) 192.168.8.106 2c:3a:e8:05:8e:eb
Tue Dec 4 17:27:33 2018 daemon.info dnsmasq-dhcp[4082]: DHCPREQUEST(br-lan) 192.168.8.106 2c:3a:e8:05:8e:eb
Tue Dec 4 17:27:33 2018 daemon.info dnsmasq-dhcp[4082]: DHCPACK(br-lan) 192.168.8.106 2c:3a:e8:05:8e:eb Power2-13
Tue Dec 4 17:27:33 2018 daemon.info dnsmasq-dhcp[4082]: DHCPDISCOVER(br-lan) 2c:3a:e8:04:eb:35
Tue Dec 4 17:27:33 2018 daemon.info dnsmasq-dhcp[4082]: DHCPOFFER(br-lan) 192.168.8.176 2c:3a:e8:04:eb:35
Tue Dec 4 17:27:33 2018 daemon.info dnsmasq-dhcp[4082]: DHCPREQUEST(br-lan) 192.168.8.176 2c:3a:e8:04:eb:35
Tue Dec 4 17:27:33 2018 daemon.info dnsmasq-dhcp[4082]: DHCPACK(br-lan) 192.168.8.176 2c:3a:e8:04:eb:35 Power1-12
Tue Dec 4 17:27:34 2018 daemon.notice netifd: wwan (4168): udhcpc: sending discover
Tue Dec 4 17:27:35 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:28:00 2018 daemon.info dnsmasq-dhcp[4082]: DHCPREQUEST(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Tue Dec 4 17:28:00 2018 daemon.info dnsmasq-dhcp[4082]: DHCPACK(br-lan) 192.168.8.118 00:21:5d:31:7f:06 DESKTOP-V9P3K86
Tue Dec 4 17:28:01 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:28:01 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:28:01 2018 daemon.warn odhcpd[1253]: DHCPV6 CONFIRM IA_NA from 000100012167358700e04c680f62 on br-lan: not on-link fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:28:01 2018 daemon.warn odhcpd[1253]: DHCPV6 SOLICIT IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:28:01 2018 daemon.info dnsmasq[4082]: read /etc/hosts - 4 addresses
Tue Dec 4 17:28:01 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/odhcpd - 0 addresses
Tue Dec 4 17:28:01 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/dhcp.cfg02411c - 3 addresses
Tue Dec 4 17:28:01 2018 daemon.info dnsmasq-dhcp[4082]: read /etc/ethers - 0 addresses
Tue Dec 4 17:28:02 2018 daemon.notice odhcpd[1253]: Got DHCPv6 request
Tue Dec 4 17:28:02 2018 daemon.warn odhcpd[1253]: DHCPV6 REQUEST IA_NA from 000100012167358700e04c680f62 on br-lan: ok fd3d:18f2:c7fd::b25/128
Tue Dec 4 17:28:02 2018 daemon.info dnsmasq[4082]: read /etc/hosts - 4 addresses
Tue Dec 4 17:28:02 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/odhcpd - 1 addresses
Tue Dec 4 17:28:02 2018 daemon.info dnsmasq[4082]: read /tmp/hosts/dhcp.cfg02411c - 3 addresses
Tue Dec 4 17:28:02 2018 daemon.info dnsmasq-dhcp[4082]: read /etc/ethers - 0 addresses
Tue Dec 4 17:28:05 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:28:09 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:29:09 2018 daemon.info odhcpd[1253]: Using a RA lifetime of 0 seconds on br-lan
Tue Dec 4 17:29:11 2018 daemon.info dnsmasq-dhcp[4082]: DHCPDISCOVER(br-lan) 00:0a:f5:53:42:64
Tue Dec 4 17:29:11 2018 daemon.info dnsmasq-dhcp[4082]: DHCPOFFER(br-lan) 192.168.8.132 00:0a:f5:53:42:64
Tue Dec 4 17:29:11 2018 daemon.info dnsmasq-dhcp[4082]: DHCPREQUEST(br-lan) 192.168.8.132 00:0a:f5:53:42:64
Tue Dec 4 17:29:11 2018 daemon.info dnsmasq-dhcp[4082]: DHCPACK(br-lan) 192.168.8.132 00:0a:f5:53:42:64 android-76e2be43afeefe9f
