MT3000 4.6.6 repeater cannot get IP address
Using openwrt-mt3000-4.6.4
Same effect with openwrt-mt3000-4.6.6
I now no longer can connect to my 2 home WiFis - “Getting…”
It’s so annoying as I really like the router - but without being able to connect to WiFi it does not help.
If I can support with sharing logs etc please let me know!
Did you try a 2nd time? Usually when I try again it will just fine.
Yes pls send me the log once this happens.
Well tried over several days, several times.
In the beginning I thought, it is the DHCP-Server as both my WiFis use the same DHCP-server.
But the moment I connect the Router via Ethernet, the IP-address is retrieved within Milliseconds.
Will share logs later this week
Just want to confirm. Are you using op24 firmware?
Standard firmware is 4.6.8 now
op24 firmware is 4.6.6
I've seen something similar some time ago. Can you change the MAC and try again.
