Upgraded from 4.7.0 to 4.7.4.
Have a USB 3.0 drive attached to the router for network storage. Use it via SAMBA on Windows 11. No issues.
After the upgrade my PC would not reconnect to the shared drive I had mapped (\192.168.8.1\NAS Backup). I could connect to the drive itself using \192.168.8.1, but not the shared name.
Deleted the share from the router. Created a new one with a different name. That worked fine. I then renamed it back to what I had originally "NAS Backup" and again it would not connect. Changed name to "NAS_Backup" and remapped drive on computer and works OK again.
So, either there is an issue with spaces in the name for the new version, or there is something still hanging around in a config file with the old name that needs to be cleaned up.
Not sure why the upgrade caused the issue, but wanted to pass it along in case others had a similar issue.
