Hello! Hope the title makes some sense. I probably have some very simple questions here but I'm not at all network savvy and I hope you may be able to help me with my ideal setup. I will describe what I currently have and what I wish to achieve since I would probably get the technical terms wrong.
I have the Beryl MT3000. Its WAN port is connected to my ISP router's LAN port. I have a Wireguard VPN (Mullvad) set up and working nicely. Devices connected to the Beryl can access the interface on 192.168.8.1 and all the devices connected to it are getting IPs like 192.168.8.x.
I however can't access my ISP router's page at 192.168.1.1 nor can I access my NAS which is connected to it. On the Beryl, on the VPN Dashboard I enabled Remote Access LAN for Wireguard but that didn't seem to be the correct setting.
Is it possible to set up such that I can access everything on ISP router's LAN while all the Internet traffic goes through the Wireguard VPN on the Beryl?
Maybe instead the Beryl can get an IP like 192.168.1.2 and then my laptop and other devices can get 192.168.1.x?
Anyhow, if this makes little sense I will try to explain myself better. Thanks in advance!
EDIT: Forgot to include this necessary information.
- Which router (which model?) are you using? Beryl GL-MT3000
- Which firmware version is in use? v4.6.0 Beta
- How is your router connected to the Internet? Explained in post
- Which DNS server do you use? I am not sure if safe to post this. (DNS from Ethernet shows 2 IPs I think from my ISP and DNS from Wireguard show one from Mullvad I think. The mode is set to Automatic)
- Do you use DHCP or static IP addresses. DHCP I think, the default.
